Re: Compression/leakdown test results
Positive stop valve seals are made of either Teflon or Viton, and have a spring steel retainer wrapped around it to hold it fast onto the valve stem boss. These almost always require machining of the cast valve boss, although I understand that there are some available from GM for SBC that do not require machining. They are permanently fixed in place on the boss, and provide constant and "positive" sealing to the stems. "Positive" means that pressure differential between the crankcase and the induction system will allow a small amount of oil to pass, which is all that is needed for a SBC.
Umbrella type seals are used in conjunction with the standard o ring seals. They are fixed elastically to the valve stems and ride up and down with them. They do NOT form a positive seal, which is more important for a BBC, with its poor top end oiling. They function by preventing much (but not all) of the oil splash which is shed from the springs from clinging to and dripping down the valve stems and through the guides.
