62 jack handle dimensions? - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    I would appreciate it if someone could provide me the dimensions for the three segments of a 62 jack handle and what its overall length should be when extended.
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 62 jack handle dimensions?
    Troy
    I'm a little confused, a 62 jack handle has only two segments, unless you are talking about the slider being a third piece. I'll be out in the garage late this afternoon and if thats what you are talking about I will measure them for you
    • Bill O.
      • April 1, 2006
      • 542
      Troy:
      This might help a little.
      • Troy P.
        • February 1, 1989
        • 1284
        Just to clarify, there are only two pieces of rod but it is bent such that there are three dimensions of interest. The crank end has two bends that separate the handle, as extended, into three sections. I'd like to know what the length of each piece is.
        Thanks for the photo, by the way. That defines another dimension. Looks like 24" when folded.
        • Gary C.
          Administrator
          • October 1, 1982
          • 17768
          53-60 drawing attached. 56-7 dimensions quoted from 5th Edition JM; 7/16" diameter, folded length 24", tang end 24" long, handle end 22 3/4" long, round rivet head ~7/16", flattened rivet end ~5/16", bends are 90 degree sweeps with wide radius. Don't know what changed in 61-2. Gary....
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Mike E.
            • February 28, 1975
            • 5140
            61-62 had a depression in the trunk floor rather than setting it on top of the trunk mat. Business end was changed from a sppon to an "L". Specific dimensions I don't have because I'm here at work.
            Mike
            • Troy P.
              • February 1, 1989
              • 1284
              I have heard that the 62 handle is somewhat longer than the 53-61. So that's why I'm particularly curious about the dimensions on that one.
              • Troy P.
                • February 1, 1989
                • 1284
                BTW Mike, I note that Gary's drawing showing 53-60 has the "L" on the end. I agree with you that it was supposed to be a spoon shape. So the drawing in curious.
                • Joe M.
                  • April 30, 1990
                  • 1338
                  Can anyone tell me what Chevy trucks used the same JACK as the C1 Corvettes? What years?
                  • Troy P.
                    • February 1, 1989
                    • 1284
                    I don't believe they ever did use the same jack, just a similar handle. I had a 56 Chevy pickup with the similar handle but the jack was not the scissors type. It was what I would call a mechanical (rather than hydraulic) version of a bottle jack. The frame on a pickup is higher off the ground than the Corvette. So maybe a Corvette scissors jack would not go high enough to lift it.
                    • Christopher R.
                      • March 31, 1975
                      • 1599
                      This aftermarket jack is very similar to C1 jacks. You can also use your 1962 ("L") shaped end jack handle with it. (Throw the replacement handle away. One less thing to carry.) This jack will fit inside the spare wheel as the original did. Won't fool a judge. But if you paint it black, it'll fool the casual observer. Used to cost about $20.
                      • Chris H.
                        • April 30, 1990
                        • 817
                        Here is a drawing from CEC of the 62 jack handle.
                        https://www.forums.ncrs.org/showthre...78102&uid=5924
                        Question, how do I upload a drawing into a new thread? It would not let me because I had posted it previously.
