Tie rod ends for a '62 - NCRS Discussion Boards
  • B C.
    Infrequent User
    • September 30, 1987
    • 7
    Hello
    I need to replace some tie rod ends on my 62.
    Corvette Central only has ends with the grease fitting on the
    bottom.
    Does anyone sell tie rod ends with the fitting on the side?
    thanx
    BJ
    • November 30, 1997
    Re: Tie rod ends for a '62
    Originally posted by B J Coffey (11948)
    Hello
    bottom.
    thanx
    BJ
    BJ -
    Have you tried Mary Jo or Grossmueller's?
    • John F.
      • March 23, 2008
      • 2396
      Paragon $20 each. See pic. Just installed on my 62.
      John F
      • B C.
        Infrequent User
        • 7
        Thanx for the info
        Happy motoring
        BJ
        • B C.
          Infrequent User
          • 7
          I noticed Paragon lists these as 'Imported'
          Any concerns on quality?
          thanx
          BJ
            • January 31, 1988
            • 43194
            Hello
            bottom.
            thanx
            BJ
            BJ-----
            NOS examples of these C1 tie rod ends show up on eBay pretty regularly. At least, they did when I used to spend some time looking for stuff on eBay. In fact, they often didn't draw a single bid.
            • John F.
              • March 23, 2008
              • 2396
              They appear to be good quality. My mechanic said they were very good. But as everyone says, keep them greased.
              John F
              • Chuck W.
                • May 31, 2002
                • 257
                BJ-
                A note of caution... some time ago I looked at the paragon C1 tie rod ends and noted that the zerk fitting for the LH & RH ends were on different sides. Originals that I've seen were all drilled on the same side regardless of them being LH or RH ends. If memory serves me correctly, with the threads pointed down and the tie rod ball end pointed toward you, the zerk fitting should be on the left side embossment on both LH & RH.
                This may have been corrected now on the Paragon ends but you might want to check otherwise one side would be correct and the other incorrect. It is pretty easily noticed when viewing the car from the front.
                • Tom P.
                  • March 31, 1980
                  • 1814
                  I PRESUME everyone is aware that the tierod ends are also common to the 49-54 Chevy pass cars.
                    • January 31, 1988
                    • 43194
                    Tom------
                    Yes, but it's hard enough to find a 49-54 Chevrolet anymore, let alone one with tie rods in good enough shape to re-use.
                    • Tom P.
                      • March 31, 1980
                      • 1814
                      Tom------
                      True, BUUUUUUUUUUUUUUUT, if you ask for a part for a Chevy pass car, INSTEAD of for a Corvette, it may be 10 times cheaper!!!
