C3 rouge wire - NCRS Discussion Boards
C3 rouge wire
  • Jim M.
    • February 23, 2009
    • 233
    C3 rouge wire
    On my 69, I have a black wire with what looks to me as a factory connector located behind the ignition shield box or near the wiper motor. I thought that it was a rouge ground wire however, putting my tester to it, it's a hot wire. Looking at my wire diagram, it pretty much looks to me that all black wires are ground so I'm pretty confused. It enters the wiring harness that goes down to the starter and also to what looks like the heater fan area. Anyone have an idea where this wire may go?
  • William C.
    • May 31, 1975
    • 6037
    Re: C3 rouge wire
    Does the black wire have a stripe on it? '69 was about the year that Chevy used all black wires with stripes for ID in the engine compartment.
    Bill Clupper #618
      Re: C3 rouge wire
      Jim -
      There's a 16-ga. black (no stripe) ground pigtail in the starter harness that has a ring terminal at the bottom that goes under the outboard starter attaching bolt head and two connectors at the top - one for the heater blower and the other for the wiper motor. If that connector is "hot", someone may have put it on the battery cable stud instead - the ring terminal fits at either location (lousy design).
      • Jim M.
        • February 23, 2009
        • 233
        Re: C3 rouge wire
        Thanks John, I'll check that this morning. jim
        • Jim M.
          • February 23, 2009
          • 233
          Re: C3 rouge wire
          John, you were so right, thanks a million. Sure enough, it was right on the battery terminal which clears up another issue. I noticed when I got the car that someone had rigged up a seperate ground for the wiper motor ground and attached it to a bolt on the intake manifold which I thought was a little goofy but I was too busy with other issues to give it much thought at the time. jim
          • Dick W.
            • 10483
            Re: C3 rouge wire
            Proof that Bubba is alive and well
            Dick Whittington
            • Harmon C.
              • August 31, 1994
              • 3228
              Re: C3 rouge wire
              I had this same problem and the ground was burned into at a metal wire junction inside the wire loom. I also had a bubba ground to the wiper motor.
              Lyle
                • 15643
                Re: C3 rouge wire
                If Bubba keeps doing that there will be fewer Corvettes around for us to enjoy.
