I am getting ready to put the body on the frame, i was looking at the radiator schroud can any of it be in place before the drop? How many people put the steering column in as the body is put on ? Thanks for the help. RICK
1958 body drop
Re: 1958 body drop
Rick,
I would attach the radiator shroud to the body first before the drop. I attach a ratchet strap to the support and connect it to the dash through the speaker hole(when w/s is off). This helps to keep the nose from falling off.
I would not mess with the steering column until the body is on.
Rich
- Top
Re: 1958 body drop
Sorry Rick I was thinking radiator "support".
I wouldn't put any shroud pieces on yet. You'd have to have the radiator in because the shroud bolts through the support into captive nuts on the radiator, and that's more weight and chance for damage to it. It's not that hard to fit the shroud pieces later. If I recall the lower rad hose has to be on before the lower shroud goes on too.
Rich- Top
- Top
