Thermostat housing - NCRS Discussion Boards
Thermostat housing
  • Calvin C.
    • May 31, 2002
    • 240
    Thermostat housing
    Which is the correct thermostat housing, 69 300 350 motor, car built in july, maybe a picture.
    I am using the 1968-69 Corvette Technical information manual & judging guide, to get my engine ready for instal, however I can not find complete details on everything.
    Thanks for your help.
    cal
  • Calvin C.
    • May 31, 2002
    • 240
    Re: Thermostat housing
    Ok, I found the part number, 3877660, but I have been told that some of them look diferent, (part number or markings are cast different) even though they have the same part number. Is this true?
    thanks
    cal
    • Ronald L.
      • October 18, 2009
      • 3248
      Yes,
      the early ones had the number on the flange and after 68 they were on the neck.
      • Calvin C.
        • May 31, 2002
        • 240
        Originally posted by Ronald Lovelace (50931)
        Yes,
        Where on the neck, I will need to get one!
        cal
          You can't miss the emboss. It's on the upper side of the neck, running lengthwise.
          BTW, that's NOT a part number...it's the item's casting number. Often, a basic casting can be made into various final parts with the variance being in secondary operations (drill, tap, machine, add this/that item). In general, the finished PN does NOT appear on a given part.
          There ARE minor differences between various theromstat housings with the same application. I'm not sure if we really understand these differences (when the part was cast, what mold cavity was it cast in, at what casting facility)... But, if the JG book tells you to look for a specific configuration silhouette of the part, you can probably bet that that's what most judges will go by to determine factory originality...
          • Ronald L.
            • October 18, 2009
            • 3248
            This is one of two threads where we covered this topic:
            https://www.forums.ncrs.org/showthre...72940&uid=6645
              • 43286
              Jack------
              In this case, it's BOTH the casting number and the finished part number.
