1969 Stamp Pad - NCRS Discussion Boards
1969 Stamp Pad
  • Dennis S.
    • April 1, 2004
    • 228
    Re: 1969 Stamp Pad
    Happened to notice the OP's transmission was stamped twice with the VIN derivative. Placement is also different than mine. The next to the last digit on my VIN derivative is slightly raised on both. See attached photos.
      • 43221
      Re: 1969 Stamp Pad
      Originally posted by Dennis Stubee (41797)
      I am sure blocks can be skillfully decked and restamped. The stamp on the transmission case...I guess one would have to find a blank casting (are there any?) and stamp it with both the correct date and VIN derivative. That is not a machined surface.
      Dennis------
      SERVICE cases have no VIN derivative or transmission production code, although they often have other stampings.
      SERVICE transmissions have no VIN derivative, but usually have a transmission production code stamping.
      • Kenneth B.
        • August 31, 1984
        • 2089
        #18
        Re: 1969 Stamp Pad
        DENNIS
        There are a lot of castings that are blank. you need to realizt that anything is possable. NCRS posters for services has rebiuiders that have any cast & any # you want on the trany.
        KEN
        • Erv M.
          • February 21, 2007
          • 445
          #19
          Re: 1969 Stamp Pad
          Dennis------
          Joe,
          Are you saying the transmission posted here is incorrect?
          Erv
          • Tom S.
            • March 1, 2004
            • 1087
            #20
            Re: 1969 Stamp Pad
            Did they stamp all blocks CE if they were replacement? And what did they do with replacement trans cases? No CE stamped in them? I sae a 69 that had been in the same family since new and had no VIN# at all. They swear the engine had never been out! Tom Stanton #41491
              • 43221
              #21
              Re: 1969 Stamp Pad
              Originally posted by Erv Myers (46978)
              Joe,
              Erv
              Erv------
              Not at all. I think it's likely correct and original. Someone had asked if there were any unstamped cases out there and I was just describing what sort of cases would be unstamped and, thus, possible candidates for later stamping.
