1958 Borg warner 4 speed C1 - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    Could any one tell me if these dates are to early for car #406 built October 29 1957. Tail is date 6/7/57 and main case is 5/20 .Would that pass judgeing.I do not have the assembly date.Thanks
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1958 Borg warner 4 speed C1
    A local Dr has a '58(#3XXX) that he has owned since 1962; he finally restored the car 5 years ago; cast iron main case, T10-7 aluminum extension with the "SPAC" label, a sidecover with no buttressing and an assembly in the second week of June 1957 - no question about it being the one for the car
    • Mike M.
      • May 31, 1974
      • 8408
      dan: tranny dates appropriate for the vette. i see no problems for it in judging.mike
      • Dan P.
        • December 1, 1990
        • 683
        when did they start the t/107A tailhousing thanks for the reply
          Dan -
          The T10-7A tailhousing started in 1958 (and continued though 1959).
          • Dan P.
            • December 1, 1990
            • 683
            I have seen the 7A on 10/18/57 do you know of any ealier
            • Loren L.
              • April 30, 1976
              • 4104
              Digging into a 25-year old folder, I found 3 photos of 7A tailshafts made in Oct 57. Wayne Loron article two centuries ago presented a "guestimate" that the 7A was for 1958 production, based on ????
              As Always, and even more so here, BW would have USED UP T10-7 extensions before allowing the "7A"s anywhere near the line.
              Based on the Iowa doctor's car of #3XXX, I would expect early Corvettes to have a T10-7 extension.
              • Loren L.
                • April 30, 1976
                • 4104
                I should have added that all 3 photos of the 7A tailshafts also showed the mystery code "SPAC" = special performance aluminum carrier?
                • Donald S.
                  • August 31, 1996
                  • 186
                  I checked my files for a picture...seems like you guys know your stuff!
                  Don
