spot on white top?? - NCRS Discussion Boards
spot on white top??
  • Tom S.
    • March 1, 2004
    • 1087
    spot on white top??
    I have a yellow spot about the size of a dime on the white top on my 65. I cannot get it off. I have no idea what it is,it was there when I bought the car. The rest of the top cleaned up pretty good. Any ideas as what to try. I tried upholstrey cleaner,a liitle bleach, a little comet and a tooth brush and nothing! Any Ideas? The to p I believe to be original and is in fairly good condition. I would like to save it. Thanks in advance Tom
  • Gary B.
    • September 30, 1987
    • 305
    Re: spot on white top??
    What about white shoe polish to at least lighten it?
    • Edward J.
      • September 15, 2008
      • 6950
      Tom, most of the time stains into vinyl that are not removed with the typical cleaners, is of a chemical stain, its the same sometimes with interior parts that are white, generally their permanet,
      My advice is to maybe try dusting aliitle white vinyl dye onto the area.they do make a dye especially for vinyl tops if you want to re-do the top.
      • Tom S.
        • March 1, 2004
        • 1087
        I have no idea what the stain is. The car sat in the previous owners garage for 7 years and three kids. So who knows what it might be. The OOP'S lightened it some. Thanks for the help. Tom
        • Roy V.
          • April 8, 2008
          • 309
          Mr. Clean Magic Eraser, don't laugh it may work.
          1972 LT-1 Elkhart Green Coupe
          • Edward S.
            • December 1, 1986
            • 514
            I might try using a liquid white wall cleaner - I would take a paper towel fold it a few times and then soak it pretty good and place over the spot. Don't know where the spot is but the paper towel should prevent runnage, leave it for a few days and rewet the towel as need be. Good luck.
            • Susan G.
              • May 31, 2005
              • 136
              I use a solution called vinyl prep which I purchased in an automotive store which mixes paints ad dyes. It is a cleaner to use before you re dye. It took off yellow stains on my 3o year old white top. It looks like new and did not hurt the top. Keep it off your paint.
              Susan
              • Tom S.
                • March 1, 2004
                • 1087
                Thanks for all the help. The mr. Clean did not work. I am going to try cleaning the whole top a few more times and see what I have then. Tom
                • Matt L.
                  • February 23, 2010
                  • 337
                  try some lacquer thinner. i have used that in the past and it worked well on my 66 lincoln white hardtop vinyl. but i would make sure to try a hidden spot first just to be safe. lacqeur thinner would be a last resort try if all else fails. good luck.
