convertible rear bow weather stripping, do you remove the piping cord from the origin - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    This is the rubber piece that contacts the deck lid.
    I noticed my original weather stripping I took off has a small round piping cord that runs in the rubber and the new weather stripping doesn't have this.
    Am I supposed to remove the piping cord and put it in the groove of the new weather stripping? I can do that easy just need to know is that what's supposed to be done.
    if so bet theres tons that just tossed their original and didn't noticed the piping cord.
  • Terry D.
    • May 31, 1987
    • 2691
    Re: convertible rear bow weather stripping, do you remove the piping cord from the or
    Brandon
    I do not have the answer but if no one else has it call Al Knoch and ask to speak with either Al himself or his brother Dale and they will be able to answer your question
    • Harmon C.
      • August 31, 1994
      • 3228
      You need the piping cord. It usally is included in a complete top weatherstrip kit. You can reuse what you have if it is in good condition.
      Lyle
      • Brandon T.
        • October 23, 2008
        • 872
        thanks guys I put my original one in the new weather stripping and luck would have it I had a tool to do it with I finally found.
        I noticed this new stripping is a bit long and it's tapered at the end just cut it or is it tapered for a reason? I ask because about a inch from the end on both ends is a hard piece of rubber inside of the stripping wanted to make sure thats not supposed to be kept at full length and that harder piece kept before I cut it off.
        • Wayne W.
          • April 30, 1982
          • 3605
          Brandon, I would bet that when you were a two year old, you worried you parents crazy with questions. Cut the damn thing to fit, and you will find that the filler w/s fits into the plugged hole.
          • Brandon T.
            • October 23, 2008
            • 872
            haha, just want it right!
            thanks
            • Wayne W.
              • April 30, 1982
              • 3605
              thanks
              OK, Here is something to look at.
              • Brandon T.
                • October 23, 2008
                • 872
                thanks wayne
                • Brandon T.
                  • October 23, 2008
                  • 872
                  Ok there wayne more questions~ haha.
                  in the picture you can see where I cut the W/S at, a bit too long still I know but I wanted to cut too little off than too much.
                  anyway, see the open space I put a arrow pointing to? what goes there I didn't see anything in a kit or seperate that would take care of that, I'm lost? and I knwo you mentioned a "filler" so what did you mean by that? are you talking about that area?
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    You are looking right at it in the top picture.
