question on repro 427 hood emblems, I broke the aligment pin off one of my originals - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    I broke the alignment pin of the 2 on one side.
    So, are the repros you get from say paragon identical or should I look for an original 2 on ebay or something to I maintain original emblems?
    if the repros are identical I'll just order new ones.
    thanks
  • Brandon T.
    • October 23, 2008
    • 872
    Re: question on repro 427 hood emblems, I broke the aligment pin off one of my origin
    Sucks I did that because this is the finished piece! looks tons better.
    I put both sets in paint stripper (tuff stuff stripper) and got all the original black paint off then rinsed etc..put them through cardboard and put some semi black on them.
    turned out great but that one missing the alignment pin will bug me until I find another original or a identical repro
    also I'm missing a couple speed nuts on the backside, I looked on paragon theirs are silver looking my originals are black, where sells black ones like the originals?
    • Bill I.
      • January 29, 2008
      • 554
      Any small hardware store should be able to help. Also try a small auto repair garage that does painting. Bill
      • Ralph P.
        • February 1, 1990
        • 253
        Brandon... there's a NOS #2 on Ebay Motors now . See item # 140392931874
        • Brandon T.
          • October 23, 2008
          • 872
          thanks!
          now I know it's GM but is a newer GM part like that exactly like the originals? or no?
          if so I might just go ahead and order an entire new NOS set off ebay I see one set for 75, not too bad for NOS.
          but again I have to wonder although it's GM those are parts made not that long ago looks like I wonder if theres a difference still.
          • Ralph P.
            • February 1, 1990
            • 253
            I would think all years are the same ; but, others may know better...
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Hi Brandon
              If you cannot find the black speed nuts, just 'Rattle Can" the silver ones.
              Production finish was black phos, so, something like a dark gray/charcoal primer after a couple of test shots should do the trick.
              HaND
              • Ronald L.
                • October 18, 2009
                • 3248
                Black Phos speed nuts should be plentiful, even at pair-a-gone
                • Brandon T.
                  • October 23, 2008
                  • 872
                  I'll take a look on some sites again all I was seeing was silver tho.
                  Ronald, you not related to a shannon lovelace are you? it's the only other person I've ever heard with that last name.
                  it's a he, and he is in nuclear and I know he was originally from Michigan.
                  • John L.
                    • November 1, 1993
                    • 74
                    Brandon
                    The trim pieces your talking about are hard to find. Paragon use to sell gm trim pieces however one side was rough due to wear on the casting mold. They don't sell the gm pieces anymore. The trim pieces that everyone sells now are made in China and they don't fit right. I also heard the chorme doesn't last. I had pieces from Paragon however a dishonest restoration shop owner switched my gm parts for the China repo. I was able to purchase a gm set on e-bay but it wasn't cheap.
                    John..........
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Brandon, not that I recall, those old large family reunions with all the second and third cousins stopped after all the grand parents either moved to Florida or passed and that was a long time ago.
                      John, don't you love those resto shops! from this thread did you get want you needed off the flee or are you still looking for the correct part?
                        • 15616
                        Don't forget the sealant to go with those black speed nuts -- you wouldn't want water dripping from the emblems onto your engine would you?
                        • Terry B.
                          • August 31, 1999
                          • 607
                          Brandon,
                          I would not take the risk on purchasing this type of material on ebay. I would go directly to the maker, Trim Parts in Lebanon, Ohio. Here is what I found on a quick search: http://www.trimparts.com/Pages/Resul...1&ProductCat=4
                          I would replace all the numbers, too
                          Terry Buchanan
                          Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                          Corvettes Owned:
                          1977 Coupe
                          1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                          2003 Electron Blue Coupe
                          2019 Torch Red Grand Sport Coupe
                          • Brandon T.
                            • October 23, 2008
                            • 872
                            Don't forget the sealant to go with those black speded nuts -- you wouldn't want water dripping from the emblems onto your engine would you?
                            ah good point, honestly didn't give that a thought.
                            • Brandon T.
                              • October 23, 2008
                              • 872
                              Originally posted by Terry Buchanan (32872)
                              Brandon,
                              I think this is the place that I was told has GM molds and are 100% identical..
                              thanks
