Re: Knock off wheel spinner
Create-Your-Own Replaceable-Face Split-Head Hammers
Hammer Body (Shown with Faces, Sold Separately)
It's faster and easier to change the faces on these split-head hammers than on press-fit style hammers. Just loosen the nut under the head, remove the face, insert the new face, and tighten the nut. The hammer bodies and faces are sold separately, so you can create a custom hammer for your application.
Bodies consist of a two-piece malleable iron hammer head, a nut to secure the assembly, and a replaceable hickory handle. Faces are available in your choice of materials. Lead consists of 94% lead and 6% antimony. Rawhide provides soft blows—great for assembly work. Copper allows high-impact blows but is soft enough not to damage precision parts. Hard nitrile rubber is green and is similar in hardness to a bowling ball. Hard plastic is made of yellow ultra-high molecular weight (UHMW) polyethylene and is similar in hardness to a hard hat.
Replacement handles. Please ask for 5911A61 and specify the McMaster-Carr body part number.
Bodies (Without Faces)
O'all Face O'all
Wt., lbs. Dia. Lg. Each
1 1/2 1 1/4" 11" 5911A11 $27.52
1 3/4 1 1/2" 12 1/2" 5911A12 28.69
2 1/2 1 3/4" 13" 5911A13 32.64
3 1/2 2" 14" 5911A14 35.23
5 1/4 2 3/4" 15 3/4" 5911A15 49.74
7 2 3/4" 36" 5911A25 59.08
I highly recomment this 7-pound replaceable-face hammer. Bill Sangray wrote a story for The Restorer about it. It is not inexpensive, but then neither is having one of your wheels pass you on the road. Page down tot he bottom of the page in the link.
O'all Face O'all
, obviously not the original supplier.
