Knock off wheel spinner - NCRS Discussion Boards
    • 15621
    Re: Knock off wheel spinner
    Create-Your-Own Replaceable-Face Split-Head Hammers
    Hammer Body (Shown with Faces, Sold Separately)
    It's faster and easier to change the faces on these split-head hammers than on press-fit style hammers. Just loosen the nut under the head, remove the face, insert the new face, and tighten the nut. The hammer bodies and faces are sold separately, so you can create a custom hammer for your application.
    Bodies consist of a two-piece malleable iron hammer head, a nut to secure the assembly, and a replaceable hickory handle. Faces are available in your choice of materials. Lead consists of 94% lead and 6% antimony. Rawhide provides soft blows—great for assembly work. Copper allows high-impact blows but is soft enough not to damage precision parts. Hard nitrile rubber is green and is similar in hardness to a bowling ball. Hard plastic is made of yellow ultra-high molecular weight (UHMW) polyethylene and is similar in hardness to a hard hat.
    Replacement handles. Please ask for 5911A61 and specify the McMaster-Carr body part number.
    Bodies (Without Faces)
    O'all Face O'all
    Wt., lbs. Dia. Lg. Each
    1 1/2 1 1/4" 11" 5911A11 $27.52
    1 3/4 1 1/2" 12 1/2" 5911A12 28.69
    2 1/2 1 3/4" 13" 5911A13 32.64
    3 1/2 2" 14" 5911A14 35.23
    5 1/4 2 3/4" 15 3/4" 5911A15 49.74
    7 2 3/4" 36" 5911A25 59.08
    I highly recomment this 7-pound replaceable-face hammer. Bill Sangray wrote a story for The Restorer about it. It is not inexpensive, but then neither is having one of your wheels pass you on the road. Page down tot he bottom of the page in the link.
    • Clark K.
      • January 12, 2009
      • 536
      Originally posted by Gary Chesnut (5895)
      Rudd, you can drill and tap the hub for a set screw. Reinstall the knock off wheel and make sure you have the big holes over the lug nuts and small holes over the pins. Tighten the spinner with your lead hammer multiple times with the wheel on the ground. Drive around a block or two. Stop re-hammer. Repeat this process a couple of times. Then installed the set screw from the inside of the hub. Last use silicon to attach the cap. This process works great on the old Western Wheels. Gary....
      I agree with Gary. My Western wheels have been modified with drilled and tapped threads for a set screw. I never use the "anti-theft pins" even though the hub has the grooves for them. I use anti-seize on the hub threads and the set screw threads. I have never had to retighten a wheel after installing them. I put 'em on TIGHT! Once tight, I use a black marker "line" on the hub/spinner combination for ease of visual inspection.
      I have found that a tiny amount of petroleum jelly (on the edges of the cap that snaps into the spinner) works great on the center caps. Perhaps Gary uses silicone jelly, not aerosol silicone. -Clark
      • Wayne M.
        • March 1, 1980
        • 6414
        #18
        Originally posted by Clark Kirby (49862)
        ..... My Western wheels have been modified with drilled and tapped threads for a set screw. I never use the "anti-theft pins" even though the hub has the grooves for them. ....
        Clark -- by "set screw" do you mean a hole drilled in the spinner (near the words "OFF -->" ? I have an early set of K-H Westerns and one spinner has 2 holes, and the other has a single hole; two spinners have no holes , obviously not the original supplier.
        • Wayne P.
          • January 23, 2008
          • 444
          #19
          The two spinners with the holes probably were lock wired for racing .
          Just a guess
          • Clark K.
            • January 12, 2009
            • 536
            #20
            No, do not drill the spinner. My hub (hub adapter?) was tapped and threaded for a set screw by some previous owner. When the wheel is tight enough, I take an Allen wrench and tighten the set screw into the inside of the spinner.
            For your car to have this feature, you will have to take the four wheel hubs (the part that the spinner threads onto) to a machine shop to have the set screw threads put into it. You then have to remember to remove/loosen the set screw before you hammer the wheels off or on. -Clark
