65 engine date code? - NCRS Discussion Boards
  • Tom S.
    • March 1, 2004
    • 1087
    How do you figure out the build date on a 65 engine? I should know and remember but I cannot. Please refersh my absent memory! Thanks Tom Stanton #41491
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 65 engine date code?
    Assembly date would be on the front pad. The month and day will appear right before the suffix. Like F0104HH the 0104 translates to Jan 4. That is just a made up example, but you get the point.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Tom S.
      • March 1, 2004
      • 1087
      Tom thanks, I remember now you jared my memory. Thanks again. Tom
      • Tom S.
        • March 1, 2004
        • 1087
        Tom
        date code L304 stamp pad F0512HIxxxxxxx Help I am confused. Tom
        • Jim D.
          • 2885
          Can you post a picture of the pad?
          • Bob H.
            • July 31, 2000
            • 827
            I believe the engine block cast date will be on the top rear passenger side flange where the bellhousing attaches. Below the distributor. I believe it is month, day, year ex 1 5 5
            • Tom S.
              • March 1, 2004
              • 1087
              No I can't sorry. The car is about 500 miles away. I am going to look at it next week. Tom
                • April 1, 2000
                • 477
                The date stamp that says L304 translates to a casting from Dec 30th, 1964. The F0512HI says it's a Flint block assembled May 12th, with HI telling what application, but I don't have a ref book here with me at the moment. The xxxxxxx should be the VIN info that should match up with the VIN plate under the glove box.
                Kind of a big gap between cast and assembly, but possible and within the 6 month window, assuming body assembly and car birthday are pretty close to (and after) the May 12th date...but definitely pushing it.
                  Originally posted by Tom Stanton (41491)
                  Tom
                  Tom -
                  The "HI" suffix is a 250hp base engine with A/C, for a manual transmission.
                  • Tom S.
                    • March 1, 2004
                    • 1087
                    Trim tag reads E12,A-871,437'U-U,STD. I am just taking what the owner tells me. I am going to look at it next week. Tom
                    • Tom S.
                      • March 1, 2004
                      • 1087
                      I am geussing it is Dec. 12th on the build by the serial # and the E-12. My NCRS hand book says there was a strike in1965 so could that affect the build date and assembly date? Thanks Tom
                        Tom -
                        That's an A.O. Smith body, built in Ionia, Michigan on December 12, 1964. It would have come off the line at St. Louis a week or two later; did you post the VIN, or did I miss it?
                        The strike was over several months before that time.
                        • Tom S.
                          • March 1, 2004
                          • 1087
                          John
                          The vin # is S104996 so I am thinking mid- December ? Maybe a little later, I am using my NCRS pocket guide for referance. Thanks Tom
                            John
                            Tom -
                            Should be December 22 (give or take a day or two), per the "Birthday Book".
                            • Wayne M.
                              • March 1, 1980
                              • 6414
                              Tom -
                              Here's the P-o-P imprint off the first car I ever owned; L79 convertible # 104835, probably 2 days before Tom's. Might help to compare with some of the component stampings. Don't know if A or S-body. Was too green to even know where the trim tag was, or what it meant (June 1968).
