Re: 1967 Water Temperature Guage Test
Originally Posted by John Hinckley (29964)
Joe -
The indicated temp goes down as the resistance in the circuit increases, not up.
That's why I questioned the firewall connection, but the 60 ohm test on the sender wire confirms the wiring and guage are OK. I don't really care if the guage reads low in the mid range, I will check a few other senders to see if there is one that ohms closer at 180 temp. Mine read approx 130 ohms at 175* engine temp..
Thanks for the help, Joe..
Joe -
