1967 Water Temperature Guage Test - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5202
    #31
    Re: 1967 Water Temperature Guage Test
    Originally Posted by John Hinckley (29964)
    Joe -
    The indicated temp goes down as the resistance in the circuit increases, not up.
    That's why I questioned the firewall connection, but the 60 ohm test on the sender wire confirms the wiring and guage are OK. I don't really care if the guage reads low in the mid range, I will check a few other senders to see if there is one that ohms closer at 180 temp. Mine read approx 130 ohms at 175* engine temp..
    Thanks for the help, Joe..
