1970 Wiper Arms - NCRS Discussion Boards
1970 Wiper Arms
  • Les G.
    • December 5, 2008
    • 158
    1970 Wiper Arms
    Does anyone have any tips for cleaning out the metal tubes on 1970 wiper arms. My drivers side has a clog.
  • Dick W.
    • 10483
    Re: 1970 Wiper Arms
    Soak them in citric acid. You probably have a calcium build up in the nozzles.
    Dick Whittington
    • Dave S.
      • August 31, 1992
      • 2924
      Re: 1970 Wiper Arms
      Les,
      About 5 to 10 psi of air using a tip with a small hole that fits inside the tube worked for me. As Dick mentioned you can soak them first to loosen things up.
        • 6942
        Re: 1970 Wiper Arms
        Yet another way to clean the nozzles is a product called CLR(calcium, lime , rust) I know most hardware stores carry it. just soak over night.
        • Sal C.
          • December 1, 1984
          • 430
          Re: 1970 Wiper Arms
          I have had good luck with a tiny drill bit in a pin vice. Also have used an accetylene torch tip cleaning tool with good results.
          • Harmon C.
            • August 31, 1994
            • 3228
            Re: 1970 Wiper Arms
            Carburator cleaner with the tube in the hose end works for me. You can then see if all three holes are open by the vapor. If one of the side holes is pluged a needle will go through the open side and unplug the cloged hole as they are in line.
            Lyle
            Lyle
