Wiper Door Solenoid - NCRS Discussion Boards
Wiper Door Solenoid
  • Mike K.
    • February 24, 2010
    • 68
    Wiper Door Solenoid
    I have a 68 and need to replace the wiper door solenoid on the back of the tach. Does anyone know of an easier way to access this part short of dropping the steering column to removing half of the dash?
  • Edward J.
    • September 15, 2008
    • 6940
    Re: Wiper Door Solenoid
    Mike, I think you can reach under dash and un-hook the wire and hoses and just attach the harness and hoses to new solonoid, and tuck under the dash when done.
    • Dick W.
      • 10483
      When I was able to stand on my head, I have replaced those solenoids and attached them back to the guage cluster. Just takes a lot of patience
      Dick Whittington
      • Edward J.
        • 6940
        Dick, I use to have one of those rubber necks In my earlier days,since then my wife has knocked it loose to may times. I'm lucking to be standing.
        • Mike K.
          • February 24, 2010
          • 68
          Thanks Gentlemen:
          I appreciate the replies. Not as young as I used to be so standing on my head is tough - especially with all the extra lumps from the wifes cast iron skillet. hahaha
          • Edward J.
            • 6940
            Mike if you spend to much time in the garage, you'll be needing some duct tape to.
            • Mike K.
              • February 24, 2010
              • 68
              Thanks Mr. Johnson for the reply. It is a tough place to get too and not much room to work with the original steering wheel in the way.
                • 3415
                Hi Mike,
                I found it's easiest for a 4 year old. They can lay in the foot well, their arm is long enough to reach, and their hand is small but STONG. PLUS.... they will often work for a baggie filled with Cheerios and a ride.
                Seriously, I found it worth while to take the seat out; it takes a few minutes but it's surprising how much you can do if you can lay in the foot-well. Next is the steeing wheel drop.
                • Lawrence M.
                  • January 31, 1995
                  • 404
                  Mike, As Alan said it is much easier if you remove the drivers seat. I have not had to change the wiper solenoid, but working on other stuff under there like the brake booster attaching nuts was much easier with the seat out.
                  Larry
                  Larry
                  2002 Z51 Convertible
                  1969 L46 Convertible
                    • January 31, 1988
                    • 43191
                    Mike------
                    If you think working under the dash of a C3 is difficult, try working under the dash of a C4! You'll instantly appreciate just how easy a C3 is.
                    • Mike K.
                      • February 24, 2010
                      • 68
                      Hi Mike,
                      Alan:
                      Would probably not be a problem if my grandson was here versus in New England area. Cheerios would be a cheap labor charge by comparison.
                      Seriously, thought about taking the seat out and trying that before having to drop the steering wheel. Will definately give that a try before the other. Thanks!
                      • Mike K.
                        • February 24, 2010
                        • 68
                        Larry
                        Larry:
                        Will take Alan and your advice on the seat. Thanks for the response.
                        • Mike K.
                          • February 24, 2010
                          • 68
                          Mike------
                          Joe:
                          I can only imagine how difficult the newer vettes are to work on with all of the electronics. Thank for the response.
                          • Jim T.
                            • February 28, 1993
                            • 5351
                            my radio/casette player in my 85 was sure easier to remove than the radio on my 68 and 70. It can be done just sitting in the drivers seat.
                              • January 31, 1988
                              • 43191
                              Jim------
                              Yes, the radio on C4's are easy to remove. That's about it, though. Try to work UNDER the dash? IMPOSSIBLE. The only way is to remove the various dash pieces including, sometimes, the upper dash panel.
