Problem! Trans Speedo*Gear - NCRS Discussion Boards
  • Steve D.
    • November 1, 2002
    • 17
    HELP!
    While chasing a speedo problem it was necessary to pull the speedo adaptor out of the Transmission. The plastic gear has fallen into the tailhousing!!
    My question to you is do you think it will ride in the tailhousing and be alright?
    Or is it time to pull the transmission and get it out?? Of course I would have to replace the gear...
    1963 T-10 4 speed....
    Thanks, Steve
    • 6960
    Re: Problem! Trans Speedo*Gear
    Steve, bad idea to leave in transmisson, would say buy yourself a set off mechanical fingers maybe you can fish out, or even try to make a hook out of mechanics wire. good luck.
    • Roy B.
      • February 1, 1975
      • 7044
      Done it many times in the past and never had a problem !dont worry it'll sit on the bottom area get a new one
      • Jeff B.
        Infrequent User
        • November 1, 1991
        • 14
        I agree; it needs to come out of there. To me this is like leaving a freeze plug in the engine block that you just "knocked into" the water jacket. Somehow it just goes against my grain!
        • Timothy B.
          • April 30, 1983
          • 5203
          I don't think leaving the plastic driven gear in the tail shaft will hurt anything.
          • Dan H.
            • July 31, 1977
            • 1372
            Found a roller bearing (one) laying on the bottom of my 63 transmission, been that way for 25 years. Helps move the sludge around you know!
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • Jeff B.
              Infrequent User
              • November 1, 1991
              • 14
              You guys are probably right with leaving the gear in there. I just have that annoying voice in my ear that won't let me do it.
              • Michael G.
                • January 1, 1997
                • 1251
                Jeff,
                Those voices......those bothersome voices....ignore this one. Although yeah the gear shouldn't be there.....the truth of the matter it is! Forget about it. Functionally should not have an effect on performance nor function of your transmission. Let it go.
