70 350/300 fuel line clamps - NCRS Discussion Boards
  • Pat M.
    • April 1, 2006
    • 1579
    Early Shark clamps were discussed in the archives, but there didn't seem to be much certainty. And the JG is a bit confusing to me on this issue.
    Is the consensus that my base engine, May-built 70 should have four green, square-tanged spring clamps on the supply line, and four tower clamps on the return line?
    • 15616
    Re: 70 350/300 fuel line clamps
    Pat, my 2 centavos -- and it is not worth even that now days --
    For a 1970 I would expect the smaller spring clamps (I think red) on the return line -- you will need four with the square edge. Yes the green square-edge spring clamps fo the supply line.
    Foe 1971, and just maybe a very late 1970, I would expect the small tower clamps on the return line -- and the same green square-edge spring clamps fo the supply line.
    Now with that opinion out there let's see what Mark and Paul and Patrick and Jim and a few others have to say. This should be interesting.
      • 6950
      Pat, late 71 cars had the spring style clamps, 70 AND71 earlier cars had the tower clamps according to JG, I recently remember looking at Dave Stricklands 71 bowtie car (base engine) and he had the tower clamps on return line. my late 72 does have the spring style clamps.
      • Bill L.
        • February 1, 2004
        • 1403
        Well the JG does say tower clamps for 70 fuel lines. Mine lines at the tank have never been touched and they are spring ring. I also found a spring ring clamp rattling around the fuel lines by the fuel pump (large line, Green clamp). Bubba replaced the lines and used worm gear clamps. I went and found original red and green clamps with the sharp tangs.
        Does it make a difference on a 350/350 4 speed?
        Could the JG be mistaken?
        Bill
          • 6950
          Bill, does your car have a fuel pump with the return line? I beleive that the tank area did have green spring clamps on the supply line.
          • Bill L.
            • February 1, 2004
            • 1403
            Thanks Edward.
            Well I decided to look again. The return line back at the fuel tank is a small tower clamp. The supply line does have the green spring ring clamps.
            Anybody want to trade original red clamps for two tower clamps I have at least three of the red clamps.
            Should both the supply and return lines by the fuel pump be small tower clamps. If so, I need the tower clamps but at least have the correct PCV clamps
            Bill
              • 6950
              Bill, just the return lines have tower clamps, if you so have .
              I know there are some eras in the JG regaurding clamps, my 72 auto transmisson cooler hoses have the band style clamps, and the JG says tower clamps. which I believe the band style to be original.
                • 11668
                My June 71 car has green and red clamps, no towers.
                The Oct 71-dated 72 has green and red clamps.
                The June 72 has green and red clamps.
                That's all I know.
                • Bill L.
                  • February 1, 2004
                  • 1403
                  Does anyone still have the small clamps available?
                  Were they common on midyears as well?
                  Bill
                  • Pat M.
                    • April 1, 2006
                    • 1579
                    Thanks everyone. I'm most interested in the return line.
                    I now have red square edged spring clips on this line near the fuel pump, and worm clamps on this line at the gas tank (which I know are incorrect and got dinged for).
                    I was just wondering if I should put all red spring clamps, or all little tower clamps, on the return line.
                    Bill, according to a recent post, Dr. Rebuild may have these small tower clamps.
                    Thanks all,
                    • Bill L.
                      • February 1, 2004
                      • 1403
                      HI Pat,
                      I can say with certainty that at least the return line back by the fuel tank is a tower style. Because they were likely put on before the body drop, the screw is right on top.
                      I am interested in the two up by the fuel pump as well. I put red clamps there but now I am not so sure.
                      Bill
                      • Pat M.
                        • April 1, 2006
                        • 1579
                        It seems that no one is so sure.
                        Unless someone can give me a definite answer, I guess I'll put red spring clamps near the tank to match those I already have by the fuel pump. This will save me from changing all four clamps, and I didn't get dinged at the 08 National for the red spring clamps at the fuel pump, so even the judges must not have been so sure.
                        Thanks for the responses.
                        • Bill L.
                          • February 1, 2004
                          • 1403
                          HI Pat,
                          MIne is an early June build date so we are pretty close in terms of build date.
                          I am waiting as well. Hope u don't mind that I jumped in your thread.
                          Bill
                          • Steven G.
                            • November 17, 2008
                            • 348
                            Since my untouched Jan. 1970, L-46, 4-speed, has fuel tank off, I looked, all 4 spring clamps at tank are red, 2 sizes of course and the supply line has a red support (bracket) clamp as well, no tower clamps used. Steve
                              • 15616
