58 Disc Brakes - NCRS Discussion Boards
58 Disc Brakes
  • Brad H.
    • August 12, 2007
    • 724
    58 Disc Brakes
    My 58 needs a handful of items changed to make it I hope top flight potential, date code all glass, check springs, correct horns if needed, spiral shocks if needed or found, it has disc brakes on front, should I change this or is the deduction not going to hurt a top flight if other things are ok? Thanks, Brad.
  • Mike M.
    • May 31, 1974
    • 8383
    Re: 58 Disc Brakes
    change back to drum brakes. the disc system could be very costly on the judging field, depending on what orignal parts are missing. there are a couple of orignal c-1 comlete front suspensions currently for sale on ebay. mike
      Re: 58 Disc Brakes
      Brad -
      Essentially, deductions would be based on the original drum-brake system parts that are missing as a result of the conversion. If you review the point allocations on the judging sheets, that will give you an idea of the potential deduction. Note that when a component is missing, you lose both the originality points AND all of the condition points.
      • Brad H.
        • August 12, 2007
        • 724
        Re: 58 Disc Brakes
        Ok Thanks guys, now are the complete brake systems the major venders are selling correct for judging? Again, Thanks, Brad.
        • Jean C.
          • June 30, 2003
          • 688
          Re: 58 Disc Brakes
          Brad, call me crazy, but I'll make a SWAG and say that any repro complete brake system being offered by vendors will most likely be detected as not original from across a crowed room. Mike's suggestion of obtaining original parts (Ebay, swap meet, The Driveline, etc) is the only way to get a system that is correct for judging.
          Best regards,
