Re: I'll Try Lectric Limited Breakerless SE This Summerr
As things turned out that ground wire did not interfere with the module but this Board seems to turn off editing after so many (?) hours so I could not correct.
If you look at this pic you will see a round impression between the two vanes. That is where I believe a connector was located. I say "believe" because it was so covered in solder that I could not tell. It is obviously now gone with a little persuasion. It was probably a legitimate breaker plate ground but in doing my reading I was led to believe the ground lead wire goes from the vacuum canister to the screw at the back of the plate (condensor mount) where it now is. I don't think any harm has been done....
I am not happy with that back connector and will get a proper ground wire from NAPA (#ECH LW42) next week.
After some more research on the internet this pic shows what I had. I probably made a mistake knocking it off but the ground at the rear of the breaker plate will probably do the job as well.
