c-1 repo heater hoses - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8383
    anuybody else had trouble fitting the repo heater hoses(fromCC) to their respective fittings? seems like the ID of these repo hoses is too small to fit the nipples and elboes. mike
  • Pierre J.
    • July 31, 2000
    • 193
    Re: c-1 repo heater hoses
    I also bought heater hoses from CC for my '57. Had the same trouble, finally gave up and bought regular hoses from a local parts store.
    Pierre
    • Roy B.
      • February 1, 1975
      • 7044
      Yes ! repro's try some grease or I've heard some one has a stamp for store bought hoses.
      • Dennis C.
        • June 30, 2002
        • 884
        Mike,
        I used heater hoses from Paragon this past summer without a problem and no leaks.
        • Mike M.
          • May 31, 1974
          • 8383
          i used dishwashing detergent and took a rotary file to increase the ID of the repo hoses and still tight as hell. don't believe grease(petroleum derivatives) compatable with rubber hoses. soap works better as lubricant and won't interact negativly on the rubber. hey roy, instead of grease, use KY Jelly. jsut kiddin. I routinely have a local rubber stamp company make stamps for such occasions. mike
          • Gary C.
            Administrator
            • October 1, 1982
            • 17661
            Mike, Pete Sawatsky 918-968-2366 (store #) had correct hoses made. Gary....
            NCRS Texas Chapter
            https://www.ncrstexas.org/
            • Terry D.
              • May 31, 1987
              • 2691
              Agree with Dennis, used Paragon hoses with no problem and 10% discount to NCRS members.
              • Doug F.
                • November 1, 1983
                • 322
                in the past i have complained to cc about the wall thickness being too thin making the use of spring ring clamps imposable, sounds like they put the meat on the wrong side of the hose, the good news is our only choice of parts is no longer TMCS, Chevrolet or the local parts store, the bad news is half of the repo stuff we get won't work.
                • Roy B.
                  • February 1, 1975
                  • 7044
                  I hear that so many times and cant understand why things are not done correct
