'62 exhaust manifolds and crossover questions - NCRS Discussion Boards
  • Paul B.
    • January 31, 2007
    • 313
    Hi,
    In the judging guide it says that all '62 300, 340, and FI cars had 2 1/2" exhaust manifolds and a crossover. Was this correct regardless if they had the standard or the optional 441 off road system?
    Paul
  • Terry D.
    • May 31, 1987
    • 2691
    Re: '62 exhaust manifolds and crossover questions
    Paul
    Yes, if I remember correctly (if not someone will surely correct me) the only difference in the two is the mufflers. Off road were smaller round and sounded soooo much better!
    • Loren L.
      • April 30, 1976
      • 4104
      Please let me know if you find an "off-road" exhaust option for 1962.
      • Mike M.
        • May 31, 1974
        • 8382
        the 62 off road option was offered just this month here in cumberland.i dug out a set of off road GM muffler/pipe that i've had for near 40 years and installed them in the 62 i've got underway. i just assumed they were offered in 62. can i put them on my next to be restored c-1, a 56? can i get billy c to create some paperwork confirming the offreoads were optional in 62? help me , loren. regards,mikie
        • Mike M.
          • May 31, 1974
          • 8382
          hey loren. check out page 92 of the 2000 5th edition ncrs judging manual. Direct flow mufflers, option # 441. mikie
          • Tom P.
            • April 1, 1980
            • 1814
            Originally posted by Paul Bougie (46919)
            Hi,
            Paul
            The 62s with a 300hp and PG tranny got the 2in manifolds.
            • Loren L.
              • April 30, 1976
              • 4104
              I checked with the Commander-In-Chief, Mr. C and he assured me that by the time you're ready for judging, he will have the Engineering Change Recommendation authored by the Chief Engineer - Exhaust - and you will be listed as such Engineer. He will try to have the Patent paperwork showing you as the holder of the patent rights in the same mailing.
              So Press On, Irregardless - Mr. C has your back.
              • Paul B.
                • January 31, 2007
                • 313
                Hi Tom,
                I know you've probably forgotten more about these old crocks than I'll ever learn, but my '62 300 PG has what I am quite sure are the original pitted and correctly numbered 2 1/2" manifolds. Another friend and fellow member has a very original '62 with the same 300/PG drivetrain, also the same 2 1/2" original manifolds.
                I was more curious to know if the 441 off-road option changed anything other than the mufflers? Was the crossover still present with the round mufflers?
                Could you get them with the 300/PG combo?
                Paul
                • Jerry W.
                  • January 27, 2009
                  • 588
                  A friend and I both ordered new 340HP Vettes in 62....I ordered the off-road option, he didn't. Both had cross over pipes....Only difference was mine had Round glass pack type mufflers....His car sounded like a ***** Cat....Mine sounded like a Beast...How sweet it was.
                  • Jerry W.
                    • January 27, 2009
                    • 588
                    First time i have noticed that forumn rules automatically edit some words that might seem offensive to some.
                    guess i should have said "his car sounded like a Kitty Cat....Mine roared like a Lion" :-)
                    • Tom P.
                      • April 1, 1980
                      • 1814
                      Hi Tom,
                      Paul
                      Interesting!
                      • Barry H.
                        • April 30, 1976
                        • 213
                        Paul, One other minor point, the 300 HP had 2&1/2" manifolds, but did not have the crossover exhaust pipe. Just the 340HP & 360HP engines. The 300HP used the heat riser passage thru the cast iron intake manifold.
                        Barry Holmes #940
