brooch marks - NCRS Discussion Boards
brooch marks
  • Jon R.
    • May 31, 2005
    • 12
    brooch marks
    I have recently been judged and was told that my brooch marks on my '63 coupe were not there. I know that the block was never decked or altered in any way. I have taken pictures of the pad and compared it with other pads, my pad looks like other NCRS cars. I lost 100% of the points here for this area. What can I do to retify this. I would like to go to other meets;but not with this problem.
  • Donald T.
    • September 30, 2002
    • 1319
    Re: brooch marks
    Jon,
    Why don't you post a hi res pic of the pad. Seeing the pad is about the only way it can be evaluated. Some pads have more pronounced broach marks than others. Just depends on how worn the blade was when it cut your pad.
    • Timothy B.
      • April 30, 1983
      • 5186
      Re: brooch marks
      Jon,
      Post some pics of the pad and you will get some good opinions.
      • Michael W.
        • April 1, 1997
        • 4290
        Re: brooch marks
        Many judges are under the mistaken impression that all pads had pronounced broach marks when new. Not true. A broached surface can vary widely depending on sharpness of the tool, feed rate, tool pressure, tool chatter etc etc. The judging rules for engine pads takes this into account.
        Post a pic as others have said.
        • Harry S.
          • July 31, 2002
          • 5310
          Re: brooch marks
          Jon, to take a 100% deduct, I believe the team leader had to sign-off. Usually that means he takes a looks at the pad. Also, one of the judges should have had a detailed discussion with you. Possibly the 63/64 team leader.
          Where and when was the car judged? How was this communicated to you?
          • Dick W.
            • 10483
            Re: brooch marks
            Harry, my bet is that he took 100% of the 38 points assigned to the pad surface
            Dick Whittington
            • Jon R.
              • May 31, 2005
              • 12
              Re: brooch marks
              Attached pictures jandcrogers@charter.net
              • Joe R.
                • May 31, 2006
                • 1822
                Re: brooch marks
                Jon,
                Please try again to post the pictures. The link you included just sends an email to you.
                Joe
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Re: brooch marks
                  and, if that is what he is referring to - 38 points for no broach marks - there is nothing that can be done for that - either they are visible or they are not - need to ensure other areas of the car are up to snuff
                  Rick Aleshire
                  2016 Ebony C7R Z06 "ROSA"
                  • Mark R.
                    • September 30, 1990
                    • 127
                    Re: brooch marks
                    Jon:
                    Rick is correct. The 38 points for Stamp Pad Surface are specifically based on the engine pad having the proper machining (broach) marks. While the machining marks clearly vary in depth and clarity,from one car to another, if there is any evidence of the marks on the pad, even obtained through the use of a "broach buster" magnifer, generally full credit is given.
                    Mark
