'61 Front License Bumperette Bolts - NCRS Discussion Boards
  • Richard P.
    • July 31, 2001
    • 173
    I have a set of '61 Front License Bumperette Bolts from Paragon and one from Corvette Central. Paragon each bolt is stamped with a letter and the spacer is sort of black. Corvette Central only some of bolts have letters and the spacers are shiny like the bolts. Which one would be correct?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: '61 Front License Bumperette Bolts
    What letters on the bolt heads?
    Seems odd the CC kit has a mix of bolt heads. IMO I'd trust Paragon more.
    Rich
    • Richard P.
      • July 31, 2001
      • 173
      CC: there is only one size (4) 1 1/2" with WB 1C. Nothing on the rest.
      Par: same bolt is 1 3/4", but only (2) with WB; (4) 1 1/4" with WB; (2) 2 3/4 with TR; (6) 3/4" with TR.
      • Mike E.
        • February 28, 1975
        • 5141
        For 61-62, Original bolts that are visible with the assembly mounted are WB, NOT WB1C. Rear bolts (Hard to see when mounted) generally only have the hardening markings without a TR or any other ID mark in the center.
