Distributor - NCRS Discussion Boards
Distributor
  • Todd L.
    • August 26, 2008
    • 298
    Distributor
    Can someone tell me if this is from a corvette, if it is from what?
  • William C.
    • May 31, 1975
    • 6037
    Re: Distributor
    Ancient Mallory (aftermarket) parts from the late 60's or early 70's. Not anything GM ever put on a Corvette
    Bill Clupper #618
      • 43279
      Re: Distributor
      Todd------
      This is not a unit ever originally installed on ANY Corvette. It's some sort of aftermarket set-up and looks to be quite old----probably dating back to the 50's, maybe early 60's.
      • Todd L.
        • August 26, 2008
        • 298
        Re: Distributor
        There is a guy selling several items, there is a block he says is from a vette, 65' 327 some of the codes on it are:
        870 on top of 721, then off to the side is G29
        There is also GM 3782870
        H23 870 on top of 852
        He has heads that are double hump 461 w 2.02 valves. There are some head bolt tabs broke.
        A stripped 67 conv. is being sold for $75.00.
        Is there ever a time I would buy or accept these types of parts?
        • Steven B.
          • June 30, 1982
          • 4011
          Re: Distributor
          That Mallory unit is alot like, if not the same, as one I installed on my '57 in the 60's. Instead of rebuilding my distributor I bought the Mallory from J&G Speed Shop in New Haven, IN. It didn't work any better than my Delco so I reduilt the Delco and put it back in the '57 where it is today. As for the Mallory, I gave it to a guy with an El Camino in exchange for him moving me with his El Camino.
          Steve
          • Joe C.
            • August 31, 1999
            • 4598
            Re: Distributor
            That Mallory setup would be of enormous value to someone building a vintage racecar. Looks to be from late fifties/early sixties when dual points were in vogue. One poster claims that it's for a Mopar RB big block, but I have not been able to verify.
            There are lots of places to go to investigate further. I just Googled "Mallory YC465HP" and came up with this............among others:
            http://www.jalopyjournal.com/forum/a...p/t-79057.html
            Aha........................here is the answer:
            "YC-465-HP is for small & big block Corvette w/ tach drive. This a mechanical advance dual point 'double-life' distributor. Fairly rare."
            • Dick W.
              • 10483
              Re: Distributor
              Direct from Honest Charley's Speed Shop, Chattanooga TN
              Dick Whittington
              • Michael H.
                • January 29, 2008
                • 7477
                Re: Distributor
                That may be an old Mallory "Twin-Pole", or what ever they were called. Does the point cam have 8 lobes, like most distributors, or just four?
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  Re: Distributor
                  Back in the late 50's, it used to be that having a "Mallory Ignition" had the same connotation as having a blower does today; "I got dual carbs, dual exhausts and Mallory Ignition. Don't mess with me!"
                  Think I still have a coil out in the garage that looks llike the one in the photo, only it's called a "Magspark". I had that sucker hanging off the firewall of my 63 for many years. Looked impressive.
                  Stu Fox
                    Re: Distributor
                    Stu -
                    Remember Kong-Jackson and W&H "Du-Coil" distributors for flatheads?
                    • Dick W.
                      • 10483
                      Re: Distributor
                      Stu -
                      We are telling our age Hinckster, but I had a Kong-Jackson ignition on my '40, along with an Isky 400 JR cam, Edmunds wide spaced intake with 2 97's, and Weiand heads. If we had that 50 years ago, we were thought of as Gods. However, the cost of transmissions and axle keys was astronomical
                      Dick Whittington
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Re: Distributor
                        I'm a little surprised that no one remembers the old Mallory distributor with two sets of points and a four lobe point cam.
                          • 15706
                          Re: Distributor
                          I considered buying one of those because my single point was always breaking up. ...also looked at the D & H Ducoil.
                          I finally bought the TI out off the "12 mile L-88", and by the time it crapped out the second time I had figured out how to make the OE single point work to 7000 revs.
                          It only took me 12 years!
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Re: Distributor
                            The dual system was an interesting concept. One set of points fired four cyl's and the other set of points fired the other four cyl's. That was supposed to eliminate the issue of point bounce and increase coil saturation time.
                            Yunick once built a large distributor that had eight sets of points, one system for each cyl. It sure looked weird!
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              Re: Distributor
                              I had a W & H Ducoil back in the late 50's as well. I didn't notice any improvement over the regular dual point Corvette unit, but it looked impressive. I think I picked it up for about $40. with coils and SUN 4-cyl. tach sender. Sold it for about $100. to a friend who raced a Chevy powered Duece and liked to show it as well. That's about all it was good for - maroon cap, two coils, aluminum housing and lots of pretty wires.
                              Stu Fox
