Crimped power steering hose clamps - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    Re: Crimped power steering hose clamps
    if you go to YearOne's website, they sell the tool and clamps. Just look under Mopar A/B/E bodies...
    Mopar used them on all the rubber fuel lines as well as the power steering return line.
    • Jim S.
      • August 31, 2001
      • 730
      I assume that you have been talking about the clamp that attaches the return line hose to the spout on the power steering pump reservoir. That was a Chevrolet controlled connection. I have a Saginaw return line hose assembly drawing 7809489 dated Feb 1969 that probably was for the 1970 model year. The Saginaw drawing references Chevrolet part number 3826278. I can't retrieve Chevrolet drawings so I don't know if that drawing is just a pipe or a pipe and hose assembly. The Saginaw return hose assembly was obsoleted on 6-11-1977. So I assume that Saginaw no longer manufactured this return hose assembly in 1977.
      Saginaw manufactured this return line hose assembly with a crimped metal collar that permanently connected the hose to the pipe coming out of the control valve as shown. To service this assembly you had to use a hacksaw to cut the collar from the hose.
      I assume that Chevrolet may have taken over responsibility for the pipe and the connection at the control valve after 1977. I am sure that they didn't use a crimped collar like the Saginaw drawing.
      One other tid bit. The Oetiker clamp was invented by a very clever Swiss engineer by the name of Hans Oetiker. Hans was a multi-millionaire who made his fortune on patenting quite simple devises such as hose clamps. The pictures by Paul Oslansky are quite revealing. The hose assembly picture is indeed a Saginaw manufactured return line hose assembly. You can readily see the Saginaw crimped collar and the loose (Oetiker?) clamp on the reservoir end. The Oetiker clamp claim to fame (and Hans Oetiker's patent) was a dimple formed into the clamp where it was crimped (again you can see the dimple in the clamp picture.) With the strengthening dimple you could make the crimp with the pinching tool shown and the tension in the connection was very stable and repeatable. Whether Chevrolet used the Oetiker clamps, I can't say.
      Because of the patents, Oetiker clamps were not cheap. However, they were very reliable. I believe that Saginaw used Oetiker clamps on their front wheel drive axles, (where the boots connected to the joints and axle shafts.
      Jim
      • Scott O.
        • December 9, 2009
        • 100
        McMaster Carr may have what you are looking for, paste address in your Search bar on upper left side Pinch Clamps are listed
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        Let us know if you find what you need
        Happy New Years! Scott
        • Paul O.
          • August 31, 1990
          • 1716
          The rubber hose portion was made by the Swan company they still make hoses to this day. I bought a garden hose made by them a few years ago.
          • Rich C.
            • January 1, 1994
            • 383
            Here are a few photos of what is called a pinch clamp and the tool used to compress it. Plus a photo of my original 1971 hose and clamp
            Paul 18046[ATTACH=CONFIG]36368[/ATTACH][ATTACH=CONFIG]36369[/ATTACH][ATTACH=CONFIG]36367[/ATTACH]
            Kegworks, micro-matic and other sell this style clamp for draft beer lines, several sizes, styles and finishes too! Just finished my draft beer set-up!
            '73 LS-4 454 owned 21 3/4 years
              • 15601
              The breath of knowledge on this forum is amazing.
              Rich will the brew be ready for the Holiday? Me thinks not.
              • Rich C.
                • January 1, 1994
                • 383
                Just missed having it done for New Years! HOWEVER, ready in time for me to tackle pulling the trailing arms for overhaul before spring! I think Sierra Nevada Celabration will be the first victim!!!
                '73 LS-4 454 owned 21 3/4 years!
