How does this Air Filter look? - NCRS Discussion Boards
  • Larry T.
    • May 15, 2007
    • 404
    I am looking for the best filter for judging (1966) without spending the big bucks for an original.
    How does this one look?
    Would I do better with something else. What have you had good success with as it regards points deducted? Thanks.
    • 43260
    Re: How does this Air Filter look?
    Larry------
    In a "nutshell", it's closer than the current GM/Delco version of the AC 212CW to the original configuration. However, among other more minor nuance differences, the filter element is easily discerned as non-original. The original used a much more "yellowish" oil-wetted, paper element. I believe the oil used is what gave them the yellowish appearance. Modern filter elements, like the one use for this filter assembly, do not use oil-wetted material and are, thus, much "whiter".
    All-in-all, though, I think this filter would be a good buy. It's not too expensive and it's closer to the originals than you can get in a current SERVICE filter. FAR, FAR better than paying BIG $$$$$ for an original element.
    By the way, it might be possible to "re-color" the filter material element by spraying on a filter oil. I've never done this and, certainly, it won't make the filter 100% correct, but it might make it "closer".
    • Michael J.
      • January 27, 2009
      • 7158
      It's a lot cheaper than the A212CW they sell at several vendors for $60+ with the silk screened instructions.
      • William C.
        • May 31, 1975
        • 6037
        Looks a lot like the available reproductions, color, wire size and other minor deficiencies will cost a point or two.
        Bill Clupper #618
        • Peter L.
          • May 31, 1983
          • 1930
          Outer support mesh looks OK and others have commented on the whiteness of the filter paper, BUT original 65, 66, and 67 AC A212CW air filters did not have "BEST WAY TO PROTECT YOUR ENGINE........." in white lettering on the black Plastisol. Pete
          • Larry T.
            • May 15, 2007
            • 404
            I am aware of that. To my knowledge there is no reproduction that comes close, so what is my best choice? Should I just get a cheap AC Delco service replacement for judging or try to duplicate the look to some degree? Which would cost me the least number of points. If it is all the same I like this one better.
              • 15624
              You might try various solvents to remove the "BEST WAY .... " If it is a real silk screen it will be very hard, maybe impossible, to remove with a solvent, but if it is an ink stamp it should yield to a strong solvent. It might be worth a try.
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1463
                Check Noland's book, pg. 282 for the R. D. mesh
                and the archives for pix of the TFP embossing.
                HaND
                • John D.
                  • June 30, 1991
                  • 875
                  So what would be the scoring difference between the repro with the incorrect mesh and element color and the current replacement that comes in a Delco box (looks like a Fram to me) which also has the incorrect configuration.
                  It certainly would help decide if the repro is worth buying on the $$$$/point calculation .
                  • Page C.
                    • February 1, 1979
                    • 802
                    This is the embosed lettering on original 1966 AC filter.
                    Page Campbell
                      • 11681
                      You gotta be kidding, right?
                      Sell it to someone who needs the "best way" words and use a different one.
                        • 15624
                        Why Patrick? It's a repop and costs $30. What's the big deal?
                        • Larry T.
                          • May 15, 2007
                          • 404
                          Let me try this again, since I am not going to spend a grand or so for an original one, and my goal is to lose the minimum points, what should I use, and why will it cost me the fewest points?
                          I do like the one in the picture for price and appearance, but will a current cheapo Chinese or wherever it is made) AC packaged service replacement cost me the least number of points for judging purposes, even though it looks even less original?
                          • Brian M.
                            • February 1, 1997
                            • 1841
                            The air filter element is worth 5 orig and 5 cond pts. At the 2007 National the service replacement element in my 67 base engine car took a 1 pt hit on orig. Take the hit and move on.
