Damage from repetative starting car without driving?? - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    Can I be setting my car up for possible damage by starting and running the engine of my car without driving it?? With the weather less than optimal lately, I've been going out nightly to the garage and starting my "60, turn on some tunes and run the car for maybe 15 minutes. Is there any possible damage to the engine/etc that can occur with this practice?
    I think I am doing the right thing for the car but I just might be mistaken.
    Any thoughts?
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Keith B.
    • March 7, 2008
    • 928
    Re: Damage from repetative starting car without driving??
    that is the worse thing you can do. just let the car be.
    • Bill I.
      • January 29, 2008
      • 554
      All you are doing with that is bringing the oil up to near operating temps. The rest of the drivetrain is just sitting there NOT heated up. You are putting more strain on everything by doing this . Just put a 'float' charger on the battery and forget about it. Bill
      • Robert S.
        • May 31, 1988
        • 81
        Disconnect the battery, connect a battery tender to the battery, and let the car sleep soundly until the good driving weather returns.
        • Michael L.
          • December 1, 1998
          • 97
          Do Not forget to put stabilizer in the gas it goes bad Much quicker then you will
          think Good luck and enjoy
          Michael E Leeds
          Charter Member
          Past Chairman Louisiana Chapter
          Past Vice Chairman Louisiana Chapter
          Past Show Chairman
          31462-La-46
          River Ridge LA
          www.ncrs-louisiana.com
          • Michael W.
            • April 1, 1997
            • 4290
            As previously advised:
            https://www.forums.ncrs.org/showthre...466#post462397
            90% of engine wear occurs during engine start. If you've been doing this for a while, the oil has probably been diluted and contaminated with blowby from the combustion chambers. Best change the oil asap and don't start the engine unless a good long drive is planned.
            There is NO need and NO benefit in starting an engine just to let it run.
            • Jim D.
              • 2885
              Total waste of money. Gas will be fine for 1+ years without any added snake oil. I've never used it and have never had a problem.
              • Don H.
                • December 1, 1981
                • 1501
                The discussion here converted me to changing the oil in the fall instead of spring. That way the engine sits with new oil coating the parts. Don H.
                • Valeria H.
                  • July 27, 2009
                  • 463
                  Thank you to everyone that responded. I try to take the old girl out as often as possible but it has not been possible lately.
                  Dang, I have really enjoyed my start ups at night with the old tunes coming out the radio and a glass of wine.
                  What are the qualifications for a great battery tender? I know there is a differance.
                  Valeria
                  Valeria Hutchinson
                  • Robert I.
                    • July 31, 2004
                    • 164
                    <Total waste of money. Gas will be fine for 1+ years without any added snake oil. I've never used it and have never had a problem.>
                    On our lawnmowers, some years I forget to add Stabil. It doesn't seem to make any difference.
                    But on our boat, which is a much higher performance engine, when it's winterized, they add a stabilizer. Seems like it runs horribly until that tank of gas is used up.
                    ____________________
                    Bob Immler
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Use the Satbil, the gas goes bad, and gums up the system, lawn mowers included. The fuels these days have a higher propensity for this due to their alcohol content that, absorbs h2o from the air left in the toop of the tank, put it in fill er up. In hot humid type climates, this happens in 6 months,I've had the experience, again depends on the fuel.
                      Same goes for the oil. Good oil has antioxidants, remember to take your vitamins! and give some to your car too. Change in fall cycle her good and rest assured. I had one stored that way 8 years un touched and it went vroom when the started.
                      • Gerard Q.
                        • February 1, 2000
                        • 284
                        Valeria
                        One of these should do the trick.
                          • 15646
                          Valeria
                          I would be concerned about breathing all that CO2, or my propensity to fall asleep (permanently) with the music and spirits -- but that's me.
                          I have several Battery Tender + units ($45 or so) that have worked well for several winters. The C6 needs battery support when parked for more than a couple of weeks. I also have a Battery Minder ($20, but I got mine as a door prize at a chapter event) that I am using for the first time this year. Jury is still out on that one, but so far nothing negative to report.
                          I see there are battery maintainer units from as low as $5 on sale at Harbor Freight to as high as over $100 from some of the boutique auto suppliers. There have been other threads on here about just this subject in which others have reported on their experiences.
                          A couple of things to watch for: Look for a unit that will de-sulphate the battery. I am not sure they will bring back the dead, but this feature should reduce the chance of sulphation. Look for units that will also maintain the charge on gel cells and AGM type batteries. This could be an advantage in the future as these styles of batteries become more common.
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            That's what I use. The car sits from Novemberish to Aprilish with a tender attached and starts first turn of the key in the spring. No Stabil or avgas any other magic elixir.
                            • Valeria H.
                              • July 27, 2009
                              • 463
                              Thanks for all the great advise. I'm going to do an internet search for a bettery tender with the specs you have suggested.
                              Valeria
                              Valeria Hutchinson
