Damage from repetative starting car without driving?? - NCRS Discussion Boards
  • Chris L.
    • November 1, 1998
    • 275
    #31
    Re: Damage from repetative starting car without driving??
    I used stabilizer in my generator and lawn mower last winter ans had to have both carbs rebuilt due to being gummed up! Not a happy camper in the spring. I would'nt even consider putting it in my car gas tank. I threw the bottle(full) in the trash.
    • Brad H.
      • August 12, 2007
      • 724
      #32
      Put it up on blocks and run it through the gears if you just want something to do, brace your pedal at 60 and let it run, open your doors to clear out the funk. Brad.
      • Timothy B.
        • April 30, 1983
        • 5196
        #33
        Never had a problem with Stable in any gas tank. If it's used, the engine needs to be run to disperse the product.
        Those little mover carburetors have a small hole in the up tube before the main jet that gums up from sitting. Does not take for gas to go bad in the little bowl.
        • Kevin G.
          • February 1, 2005
          • 1076
          #34
          One point that I haven't heard anyone mention, would be damage to the rear and undercarriage of the car, (bumpers, rear hardware, exhaust pipes, mufflers, etc.). Just recently at the Florida Regional I over heard one of the judges make a comment "this car must have spent a lot of time idling". In other words the rear of the car is aged more so then the front due to condensation from the exhaust. I simply change the fluids and zip them up in the Car Jacket and wait for spring.
          Kevin
          • Valeria H.
            • July 27, 2009
            • 463
            #35
            I think I understand now why I was having difficulty pulling up a previous post after I posted it. Correct me if I am wrong as this has occurred several times. When I looked at the posting from the listing of subsequent names that posted I came to a title that stated something like 'other postings underneath' and I was able to pull the post up from there.
            Have others had this experience?
            Valeria
            Valeria Hutchinson
            Past Chairman of the Carolinas Chapter
            1960 Roman Red w/ White Coves -"Bella"
            2005 Millennium Yellow 6 speed 400 HP - "Trixie"
            • Bill I.
              • January 29, 2008
              • 554
              #36
              Happens to me also Val. Don't care for it all. Would rather see something like pg. 2. Bill.
              • Valeria H.
                • July 27, 2009
                • 463
                #37
                Thanks Bill,
                I did not want to be labeled (CBS) otherwise known in the medical field as crazy bitch syndrome.
                Valeria
                Valeria Hutchinson
                • Jim S.
                  • August 31, 2001
                  • 730
                  #38
                  Valerie,
                  You aren't the only one that has had a problem trying to follow the postings. At some point they are also going to have to bite the bullet and split up the C1s, C2s, C3s, etc. Two pages a day of threads gets too much to try to follow.
                  Jim
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    #39
                    Originally posted by Gerard Quinn (33629)
                    One of these should do the trick.
                    I have two Battery Tenders. I would not be without them. The investment is worth it.
                    • Dan D.
                      • November 5, 2008
                      • 1323
                      #40
                      I agree with both of your comments. -Dan-
                      • Gerard Q.
                        • February 1, 2000
                        • 284
                        #41
                        Valeria
                        Logging in eliminates this issue.
                        • Valeria H.
                          • July 27, 2009
                          • 463
                          #42
                          Gerard, Do you mean logging out first and then logging back in?
                          Valeria
                          Valeria Hutchinson
                          • Gerard Q.
                            • February 1, 2000
                            • 284
                            #43
                            While logged in I don't see the "more replies below this line". When I'm not logged in I do see it in large threads. I have my thread view set to:
                            1. Linear Mode (Oldest First) - In this mode, posts are displayed chronologically from oldest to newest. Posts are shown in a flat mode so that many posts can be viewed simultaneously.
                            in my User Profile.
