C2 Rear cross over brake line - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    The rear cross over brake line in my 66 is in two sections with a brass connection approximately half way between the hose connector and the centerline of the car.
    I believe this to be incorrect per the AIM and about to remove and replace it with a one piece line.
    Before I do this, was there any possibility that this was ever done this way by the factory?
    Also, who do you recomend for this part.
    Thank you,
    Ralph
  • Mike M.
    • May 31, 1974
    • 8409
    Re: C2 Rear cross over brake line
    original cross-over tube was one piece. if you're having the 65 judged, get mild steel. if not, buy the stainless repo.i believe both available from Paragon of Corvette Central .mike
