Exhaust manifold Paint - Factory Photo!! - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    Check out this photo.. What year?
    • 6942
    Re: Exhaust manifold Paint - Factory Photo!!
    Ken, Im thinking 57 those style flywheels are not around in the 60,s
    • Steven B.
      • June 30, 1982
      • 3990
      It appears the flat surface on the exhaust manifolds where the choke tube goes in is not painted on the 3-4 engines nearest.
      Steve
        • 6942
        The engines were pass. car motors, 2 bbl intake manifolds , the 6 cylinder motors, were Bel Airs, biscaynes, or light trucks
        • Cecil L.
          • May 31, 1980
          • 449
          It's at least 58 since those two barrel powerglide engines are marked with a "D" code on the ends of the heads.
          There was a series of pics posted from an old Life Magazine issue in 59 showing the assembly plant operations. This is probably one of them.
            • 6942
            Cecil, wasn,t the power guide in 57 too?
            • Cathy S.
              • August 31, 2003
              • 293
              Great photo! Thanks for posting
              Greg
              • Cecil L.
                • May 31, 1980
                • 449
                Yes, but there was no "D" code in 57, it was "F" for the 2 barrel powerglide 283.
                • Rich P.
                  • January 12, 2009
                  • 1361
                  I have seen these photos before on the internet. If you do a search on the internet of Time Life photos for 59 assembly line photos they will come up. So to answer your questions these are 59's.
                  Rich
                  • Sander B.
                    • March 1, 2005
                    • 499
                    here the rest of the great picture's
                      • 43221
                      Ken------
                      Keep in mind that there were differences in the engine plant assembly and painting sequence at the different engine plants and, also, changes which happened at the individual engine plants over the years. As a matter of fact, these photos were, apparently, taken at the Tarreytown, NY assembly plant which likely sourced their V-8 engines from Tonawanda. So, what is shown here are most likely Tonawanda-manufactured engines.
                      In 1959, the Tonawanda assembly process called for the installation of the manifolds prior to engine paint. However, the Flint assembly process installed the exhaust manifolds after engine paint. All Corvette small blocks were, of course, manufactured at Flint.
                      • Lynn H.
                        • December 1, 1996
                        • 514
                        Just asking questions, but even though passenger car engines, wouldn't they have most likely come from Flint? And if so, does anyone know or have any idea of WHY they would have painted the exhaust mnanifolds on these small blocks, and NOT those for Corvette application?
                        Lynn
                          • 43221
                          Lynn
                          Lynn------
                          Since these photos were taken at the Tarreytown, NY assembly plant, it's most likely that the small block engines would have been sourced from Tonawanda NY. Tonawanda, which most folks think of as the "big block plant", manufactured a LOT more small blocks than big blocks. Given production volumes of big blocks even at that time, I doubt that Chevrolet could have justified having a plant which manufactured only big blocks.
                          • Lynn H.
                            • December 1, 1996
                            • 514
                            Ken------
                            Thanks Joe, once again your fountain of knowledge overflows and splashes the rest of us.
                            Lynn
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Ken------
                              Are you refering to just 1959 Flint engines or all Flint engines?
