'61 Rear Axle Vent - NCRS Discussion Boards
'61 Rear Axle Vent
  • Richard P.
    • July 31, 2001
    • 173
    '61 Rear Axle Vent
    At a recent NCRS judgung I was told my 1961 needs a rear axle vent. I find two, one is metal (appears to be brass) and one is plastic. Which is correct?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: '61 Rear Axle Vent
    if the rear is a Posi, then ya need the metal tube that exits the top drivers side of the axle housing. if the vette was a non-posi, then a small plastic breather inserts into the top drivers side of thje housing. mike
    • Edward L.
      • 278
      For a non-posi the breather will be metal. It is quite small, and resembles a mushroom. (stem and cap) I believe the plasic vent is the currently available replacement part
      • Dennis C.
        • June 30, 2002
        • 888
        If a metal vent is what you need, Corvette Central has one. The part number is 581093. I don't know if it is configured as the original.
        Dennis
        • John F.
          • March 23, 2008
          • 2419
          I changed out a non-posi for a posi rear end in my 62. The hole in the top of the axle housing was not tapped for threads. I used the CC fitting with the vent tube running over to the center section. I got a 1/8-27 NPT pipe thread tap at the hardware store and greased it up so no metal filings would fall into the axle housing. Make sure you get it started straight.
          John
