gas door emblem - NCRS Discussion Boards
gas door emblem
  • Joseph Y.
    Infrequent User
    • March 1, 1992
    • 18
    gas door emblem
    is there a special tool to stake die cast studs of gas door emblem or a way to do this on a 68
  • Joseph K.
    • August 26, 2008
    • 407
    Re: gas door emblem
    I believe that the gas tank emblem is put on with stud nuts. My 69 had nuts on the studs.
      • 6957
      Re: gas door emblem
      The 68 gas door emblem was peened over on the door. no nuts 1 yr only.
        • 43279
        Re: gas door emblem
        Joseph-----
        I'm sure there was a special tool the factory used for these "spun" rivets. However, I've never seen one and I have no idea where one could find such a tool.
        The thing that's always surprised me is this: the zinc diecast material that the emblems are cast from is usually quite brittle and not, at all, malleable like steel, copper, aluminum, and other metals. I don't understand how they ever got this to work. A problem with it is implied, though, by the fact that for 1969 they went to a more conventional fastening system for both the emblem and the lid-to-hinge.
        They still used the idiotic hold-open and hold-closed mechanism, though. They finally got that right in 1971. I think the 68-70 mechanism was a "carry-over" from the GENERALLY same sort of mechanism used for C2's. However, for most C2's the fuel door assembly was received by St. Louis as a complete assembly from the supplier.
