Pirelli new old tires - NCRS Discussion Boards
  • Paul K.
    • February 1, 2002
    • 160
    Should i be concerned about the quality of a new set of pirelli 215/70R15w that are date 2001, they have been stored in a warehouse, They will be mounted on my 66
    Paul klemetson
    • 15706
    Re: Pirelli new old tires
    Accurately state the specific model, proper size (your size listing is not correct), service description, and ply construction. All this information is molded into the tire.
    For example the Pirelli P4000 Super Touring model would be size and service description 215/70ZR-15 98W, and the ply construction is listed in fine print on the sidewall.
    Quote all this information accurately, so we know exactly what you have.
    Do you know the location of the warehouse they came from and whether it is climate controlled? A non-climate controlled warehouse in a hot climate like Phoenix will cause more rapid deterioration than a climate controlled warehouse or a non-climate controlled warehouse in a mild climate.
    Carefully inspect the tires. Do they have any cracks, anywhere?
    • Bill I.
      • January 29, 2008
      • 554
      Paul, 9 year old tires are boardering on being dangerous . I would be very careful with this one. Bill
      • Tom H.
        • December 1, 1993
        • 3440
        Based on recent information published on aged tires, I'd say these would not be a wise choice. Especially if you intend to do much driving. JMO.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Paul K.
          • February 1, 2002
          • 160
          Thanks for the response, i did not purchase them
          Paul
          • Dick W.
            • 10483
            Under NO circumstances would I purchase a set of tires 5 years old, let alone 9. In a fleet environment we observed almost 0% failures in tires 4 years old or less. After five the failure curve started a steep climb, each additional year the curve got steeper. Personally I have experienced almost no failures on tires under 5 years old with the exception of the occassional foreign object in the tire. We blew three out of six tires on my trailer before they were six years old. These were not el-cheapo trailer specials, but Michlein 8 ply light truck tires that had the air pressure checked and maintained at least 4 times a year.
            Dick Whittington
