C2 French Locks - NCRS Discussion Boards
C2 French Locks
  • David F.
    Infrequent User
    • March 1, 2005
    • 17
    C2 French Locks
    I am restoring a C2 big block with French Locks on the exhaust manifolds and rear half shafts. When I tighten the bolts, the French Locks want to twist or bend with the rotation of the bolt tightening. I am using the spacer washers between the manifolds and French locks. Any trick to keep this from happening? Thanks
  • Mark P.
    • May 13, 2008
    • 951
    Re: C2 French Locks
    first straighten any bent french locks. then put some never-sieze or anti-sieze on both sides of the French lock where the bolt goes through it.
    • Twan B.
      • June 30, 2005
      • 210
      Re: C2 French Locks
      I think you put to much tork on the bolds, they just need 20 lbf.ft
      Just dit mine on my '65 SB with no problems.
      Gr,
      Twan
      #44079
