3748770 Heads - NCRS Discussion Boards
3748770 Heads
  • Loren L.
    • April 30, 1976
    • 4104
    3748770 Heads
    In Sept '07, there was a query on this board about 3748770 cylinder heads that did NOT have X58 cast into the side. The basic answer provided here was to contact the judging team leader. No follow-up answer was provided. My 1990 version of the JG also called out the "X58".
    Today I looked at two 770 heads (Sept '57 and Jan '58) that also did NOT have an "X58" casting and they are Flint castings. Surely there must be an answer to this question?????
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 3748770 Heads
    Loren,
    Think the question was asked and answered by you. I also had a set of 770 heads that did not have the X58. Don't remember the date.
    JR
    • John N.
      • February 1, 1975
      • 451
      Re: 3748770 Heads
      Loren Joe
      In the same vain as the 58X, I have two 56 Flint blocks that do not have the hex head oil plug in front. When it warms up I might take and post pictures. Have a good weekend.
      Regards
      • Mike M.
        • May 31, 1974
        • 8408
        Re: 3748770 Heads
        i have a 55 265 flint block that also lacks the plug. mike
        • Loren L.
          • April 30, 1976
          • 4104
          Re: 3748770 Heads
          I'm not sure what the little checkmark means - "Don't Answer"? - but after 105 views, 4 "newcomers" (#14, 171, 912 & 1011) seem to have two anomalies - neither of which rates a comment from judging teams.
          • Doug F.
            • November 1, 1983
            • 322
            Re: 3748770 Heads
            Loren, i checked stock, and all of my 770's are in the oct. , nov. range and have the 58x, i was always under the imprecision, that only initial foundry runs had the x mark to alert workers to look for flaws, i was told that by an old worker when i toured the Flint engine plant in the early 90's, was he BS'ing me? probably, but it sounds as good as any other theory i've heard,
