Troque Thurst Wheels - NCRS Discussion Boards
  • Tim G.
    • March 1, 1990
    • 1377
    I just purchased a set of 7" Torque Thrust wheels with F70 15" tires, I got these with redlines for a Z28, but I'm wondering if anyone has mounted wheels and tires this size on a mid year Corvette. They sure would look nice for a different look.
  • William C.
    • May 31, 1975
    • 6037
    Re: Troque Thurst Wheels
    Check the backspacing and also see if they have the cutouts for clearance on the brake calipers.
    Bill Clupper #618
    • Tim G.
      • March 1, 1990
      • 1377
      They're the new straight spoke ones, I'm concerned about that even though the supplier says they fit.
      • Jim H.
        • January 1, 2005
        • 52
        Re: Torque Thurst Wheels
        Tim;
        I bought Torque Thrusters for my '65. The centers fit the bolt pattern, but the inside of the rim dragged on the caliper. I sold them to my friend who has drum brakes - perfect. Hope I'm wrong and yours fit, since they do look cool. The backspacing wasn't the issue the inside diameter was.
        Good luck,
        Jim
        • Chuck S.
          • April 1, 1992
          • 4668
          Originally posted by Jim Hilton (43119)
          ...I bought Torque Thrusters for my '65. The centers fit the bolt pattern, but the inside of the rim dragged on the caliper. I sold them to my friend who has drum brakes - perfect. Hope I'm wrong and yours fit, since they do look cool. The backspacing wasn't the issue the inside diameter was...
          That has always been the story I've heard. There is a late design rendition of the old Torque Thrust wheel that is supposed to fix the caliper interference problem, but they have a slightly different appearance than the old Torque Thrust D's that I prefer. Tim may have the later design, and if so, they will work. I believe the only way to know for sure is to try them on a car.
          I also have a brand new, unused set of AR Torque Thrust D's. When I bought them, I went down to Discount Tire and told them the story I had heard about the caliper interference on C2/C3 Corvettes. The manager supposedly called AR to confirm that they would fit on a 70 Corvette without problems. He reported that the manufacturer said these would work, and I ordered the set.
          Now, that area of the country does not produce many rocket scientists or many priests IMO...I suspect one of two possibilities: (1) The manager couldn't get a definite answer, and decided, "What the hell, I'll sell them to him and if they don't work out, I'll fix it", or (2) AR still had the old original drawings around and machined a special set just for me. What the manager did not count on was that I wouldn't be using them for 20 years in order to discover they wouldn't work; in any event, the end result was the same for him.
          Hmmm, just ruminating here, but I wonder if one could find anyone with a big lathe that would make a skim cut on the ID of the wheel to eliminate the dragging. Yeah, I know, it's insane but the odds are the casting molds were never changed...they probably just added a little meat to the center during machining to deal with problems created by racing stresses.
          My gut tells me that there is a 90% chance of (1) above being correct, and only 10% of (2) being correct. I can't wait to try them on my restored chassis to see if that TexMex manager was a rocket scientist/incredible salesman or a lying priest.
          • Steven B.
            • June 30, 1982
            • 3990
            If they don't clear try the thinnest spacer you can find. I like the lathe suggestion form Chuck. Thicker spacers may put too much force on the studs and bearings. 'Found that out the hard way 33 years ago.
            Steve
            • Terry D.
              • May 31, 1987
              • 2691
              Why not go directly to the source. Everyone has a web site these days with contact numbers or e-mail address'.
              Certainly they would know what their product fits.
              Just my old two cents
              • Tim G.
                • March 1, 1990
                • 1377
                I could put in longer studs, shave the spokes or try a bit smaller spacer since there is a bit of room to spare.
                Thank you for your comments.
                • Terry D.
                  • May 31, 1987
                  • 2691
                  Tim
                  Who at American Racing did you talk to? Have done a ton of business with them in the past and they have always steered me in the right direction. Which Torque Thrust wheels do you have? Do you know when they were made?
                  • Tim G.
                    • March 1, 1990
                    • 1377
                    I called the Torque Thrust number directly and spoke with the individual that answered the phone. The only number I see on the wheels are AR 309, they are the straight spoke type wheels. They were sold to a friend in 2007. It's not a big deal, I have a Camaro that they fit on fine.
