Trailing Arms - NCRS Discussion Boards
Trailing Arms
  • Rob M.
    • April 30, 2003
    • 657
    Trailing Arms
    I have pulled my trailing arms off my car and have been considering using Duntov Motor Company as a source for reconditioned originals (recommended by a fellow member). Anyone have experience with them you would like to share?
    Thanks in advance
  • Wayne P.
    • January 23, 2008
    • 444
    Re: Trailing Arms
    I used Bair's very happy with product and service. Might be expensive to ship to depending if you are on the West Coast.
    • Larry M.
      • January 1, 1992
      • 2701
      Re: Trailing Arms
      Originally posted by Wayne Partridge (48428)
      I used Blairs very happy with product and service.
      I agree. My arms are currently being removed and will go to Bairs next week for rebuild. They even supply the shipping boxes to avoid damage. I would strongly consider them.
      Duntov may or may not rebuild their own arms. You could call and inquire. Often these companies will resell ones they get wholesale from a rebuilder. Could be Bairs, Ikerds, Van Steel, etc.
      Also consider Gary Ramadei for rebuilt trailing arms. He occassionally posts here......has an excellent reputation for quality work.
      Larry
      • Harry S.
        • July 31, 2002
        • 5344
        Re: Trailing Arms
        Check the thickness of the metal in all places on the T-arms. If you find lumps and bumps that may be swelling from a rust infested spot. If you find this just get new arms from Bairs. This is a safety issue that I believe overrides originality.
        • Dick W.
          • 10483
          Re: Trailing Arms
          I will second using Bairs. Yogi and Brian have been building the arms for 30 or so years.
          Dick Whittington
          • Donald O.
            • May 31, 1990
            • 1593
            Re: Trailing Arms
            Bair's is doing both my trailing arms as I write this.
            • Steven B.
              • June 30, 1982
              • 4011
              Re: Trailing Arms
              Bair's is excellent and very experienced.
              • Donald B.
                • May 31, 2001
                • 5
                Re: Trailing Arms
                Here is another vote for Bair's they did mine too, shipped me the boxes to use for transportation. Make sure you tell them if you want them to meet NCRS expectations.
                donald
                • Peter J.
                  • September 30, 1994
                  • 586
                  Re: Trailing Arms
                  Another vote for Bairs. They did mine ten years ago and no troubles since.
                  • Gary R.
                    • April 1, 1989
                    • 1806
                    Re: Trailing Arms
                    As mentioned I do them and machine fit all the parts. Takes me a lot longer but they come out the best. With that said, Bairs would be the ONLY vendor I would recommend. Brian Bair is an honest guy as is his business.
                    • Tom S.
                      • March 1, 2004
                      • 1087
                      Re: Trailing Arms
                      I have used Van steel a couple times. Very satisfied, but I have heard nothing but good about Bairs. Tom
                      • Rob M.
                        • April 30, 2003
                        • 657
                        Re: Trailing Arms
                        Thanks all for your input! I really appreciate it.
                        • William C.
                          • May 31, 1975
                          • 6037
                          Re: Trailing Arms
                          As I live about 30 miles from Bair's and have known them since the 70's I'm predjudiced, but I can also tell you that they also do the work for some of the more reputable shops across the country.
                          Bill Clupper #618
