Is there any way to tell an original C-2 hardtop wrench from a reproduction?
C-2 Hardtop Wrench Identification
Re: C-2 Hardtop Wrench Identification
I just bought a '67 black vinyl hardtop, so I guess now I'll need one of those wrenches. Where are they stored in the car? Thanks PT- Top
Dave, yes.
https://www.forums.ncrs.org/showthre...w1416&uid=3662
A 2-top car left St. Louis with the hardtop installed, and the rear hold-down bolts were inboard of the weatherstrip, so the washers weren't required. When the hardtop was removed, the bolts were removed from the top and re-installed, and the rubber washers were used between the bolt head and the ferrule to keep water from leaking into the rear compartment, as the bolts were outboard of the soft top rear weatherstrip; that's detailed on the lower portion of page 29 in the '67 Owner's Manual.- Top
Thanks Harry and John, I didn't know it was that involved. I'm getting the car judged at the Gettysburg Regional in May and will just leave the hardtop off until that meet is over. PT- Top
John, We have discussed this many times before, but it still seems funny to me that they installed that sticky dum-dum on those bolts to hold them on the hardtop, and then asked the customer to remove them for installation when the top was removed. Also original bolts that I have seen had ground off head surfaces and look bad. I know it says so in the owners manual, but it is still a hard pill to swallow.- Top
I know, but that's the way it was designed. Probably why the vendors sell those slick little polished stainless snap-in buttons to fill the bolt holes - they look better.- Top
Dave,
Here's a pic of one of the wrench's.
JRAttached Files- Top
