Air Cleaner Lid - NCRS Discussion Boards
Air Cleaner Lid
  • Steve B.
    • March 1, 2002
    • 1191
    #31
    Re: Air Cleaner Lid
    James, I would check on ebay and look for seller John Miessinger (sp). He seems to have them listed quite often. As for labels, Paul Noble may have what you need.
      #32
      Re: Air Cleaner Lid
      Geeze, Louise, isn't that car done yet, James?
      Here's my two cents: don't touch the underside of that factory original 396 air cleaner lid. Just, clean up and re-spray the upper surface. We see so FEW factory original 396 air cleaners that the odds are pretty good your Mech judges will develop tears in their eyes when they see the 'real deal' item that their vision will distort to the point of NOT seeing the condition wear/tear on the underside of the lid...
      That's my experience from having campaigned my uncle's 396 on the Duntov, Bloomington Gold, and Triple Crown circuits. I don't remember any condition deductions other than stray comments here/there (without points being taken) and MANY 'smiley face' annotations!
      • John D.
        • June 30, 1991
        • 875
        #33
        Re: Air Cleaner Lid
        One thing thats obvious on a show chrome lid is that it's noticeably heavier when compared to an original...
        • Steve B.
          • March 1, 2002
          • 1191
          #34
          Re: Air Cleaner Lid
          I agree that there are very few unrestored 396 lids with the original silk screen, rack marks. I have seen fewer that still have the original embossed labels!
          • Jeffrey S.
            • May 31, 1988
            • 1890
            #35
            Re: Air Cleaner Lid
            Attached is another example of an original lid from my '69.
            Jeff
            • David L.
              • July 31, 1980
              • 3310
              #36
              Re: Air Cleaner Lid
              Jeff,
              I have an original air cleaner assembly from a 1969 Corvette (at least I believe so) that I purchased in the Fall of 1979 and the silk screen instructions on the bottom side of the chrome cover are "straight" like yours. My original 1966 Corvette air cleaner cover has the "curved" silk screen instructions.
              Dave
                • 15616
                #37
                Re: Air Cleaner Lid
                Dave,
                I believe the silk screen instructions changed from curved to straight during the 1969 model year, so one needs to identify when during the 1969 model year the car was built.
                • Jeffrey S.
                  • May 31, 1988
                  • 1890
                  #38
                  Re: Air Cleaner Lid
                  My car is October '68 (5854).
                  Jeff
                  • David L.
                    • July 31, 1980
                    • 3310
                    #39
                    Re: Air Cleaner Lid
                    Terry,
                    I think you may be right. I have noticed that Paragon's reproduction chrome cover with the "curved" silk screen instructions is sold as a 1966-1969 cover. Maybe the extended production run (to Dec. 1969, I believe) for the 1969 Corvette had something to do with having both types of instructions.
                    Dave
                      • 15616
                      #40
                      Re: Air Cleaner Lid
                      Originally posted by David Liukkonen (3775)
                      Terry,
                      Dave
                      David that is what I would have thought -- except for Jeffrey's example. Like usual we need more data points.
                      • David L.
                        • July 31, 1980
                        • 3310
                        #41
                        Re: Air Cleaner Lid
                        The 69 Corvette 350 (exc. SHP) and the 69 Z28 (1st design) used air cleaner assembly # 6423272. The 69 Corvette 350 w/SHP and the 69 Z28 (2nd design) used air cleaner assembly # 6423907. I assume the same chrome cover was used and something was different about the base.
                        Jeff, is your 69 Corvette a 350 w/SHP or not?
                        • Jeffrey S.
                          • May 31, 1988
                          • 1890
                          #42
                          Re: Air Cleaner Lid
                          My '69 is a base engine 350/300hp car.
                          Jeff
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            #43
                            Re: Air Cleaner Lid
                            Jeff, Dave, at the end of this thread it switched to the 69's, and these two air cleaner assemblies:
                            6423272 69 Corvette 350 w/SHP
                            6423907 69 Z28 (2nd design)
                            My parts book only has the Corvette, do you know what lid/filter/base differences were for these?
                            And was 68 the initial release of these part numbers?
                            thanks,
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              #44
                              Re: Air Cleaner Lid
                              From a Corvette 74 parts book:
                              65-67,396,427, 68, 69-72 w/ SHP 350 all used the 6422188 base.
                              This base should have the vent tube larger and exiting the RH side.
                              66-67 except 427 used base # 6422931, it also references w/ 6421816-2286-3240-3907 and that string of numbers must mean (?) that this 327 base was used in those 4 assemblies ending in 1816-2286-3240-3907.
                              This base should have the smaller vent tube exiting the LH side. And in reality somewhat rare as a two year part. Were there differences between 66 & 67?
                              • David L.
                                • July 31, 1980
                                • 3310
                                #45
                                Re: Air Cleaner Lid
                                Ron,
                                FYI
                                Base # 6423910 was replaced with base # 6422188 in Nov. 1968 as per Chevrolet Parts History.
                                Base # 6423910 was used on the 67 CORVETTE w/H.D. (427) as per my 1967 Chevrolet Parts Catalog (Apr. 67) in Gr. 3.406.
                                Dave
