Brake Line Clips - NCRS Discussion Boards
Brake Line Clips
  • Christopher K.
    • September 10, 2007
    • 311
    Brake Line Clips
    Just got a brake line clip set for my '73 from a popular vendor. The smaller ones don't look like my originals. They are slightly less in width and the ridges on the sides are much bigger.
    I looked a few other vendor's pics and they all seem to look like this. I guess my only option is to clean and replate the originals?
    Thanks for any suggestions,
    Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
    • 3418
    Re: Brake Line Clips
    Hi Chris,
    I found the same situation for the fuel and brake line clips on my 71. The new clips all seemed to be just 'close' to the originals in configuration. So I ended up replating the originals as you're thinking of doing.
    Merry Christmas!
    • Christopher K.
      • 311
      Thanks Alan,
      Just cleaned up one of my originals and it looks real nice. It actually has 5/16 stamped on the round line end, and a "p" on the front flat portion.
      Merry Christmas!
      Chris
        • 6956
        Alan,What type of plating were on the clips was it a zinc or cad. plating
        • Christopher K.
          • 311
          Here's a couple pics of the 5/16" clips (little fuzzy). Looks like zinc plating for '73.
          Chris
          Chris
            • 6956
            Chris, Thanks for the pic.s, I have my original clamps and cleaned them up but none of the plating is left, I used a electric wire wheel and cleaned up nicely, they look like your pic.s I seacrhed the archives and found some answers , but still question whats correct, some say front and rear cross members clamps where a zinc plated and the ones down the frame rails were possiablely black phosphate ,as the bolts that retain the clamps are plated black.
            I would be greatful for some of you C3 guys input on the correct finishes. thanks Ed.
