63 wiper motor test? - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Can anyone tell me a easy way to bypass the switch and direct wire the wiper motor ,the engine is out so there is plenty of room to get at the wiper motor now ,and i would like to see if it operates....jim
  • Roger O.
    • September 7, 2009
    • 209
    Re: 63 wiper motor test?
    At the 3 terminals apply 12v to the center brown wire terminal, ground the yellow wire terminal and it should run on high,grounding the other terminal while the yellow is still grounded the motor should run on low.
    • Jim R.
      • June 30, 2001
      • 643
      Thanks roger.
      • Gary H.
        Infrequent User
        • September 30, 1990
        • 25
        Roger, does that test work for all midyear wiper motors??? Thanks, Gary
        • Roger O.
          • September 7, 2009
          • 209
          Yes power in the center ,grounding both outer spades motor will run on low, drop the ground from the green and the motor should run on high.
          • Joe R.
            • July 31, 1976
            • 4551
            Just a small note! The case of the WW motor must be grounded. I'm sure it was assumed you knew that! And probably did!
            JR
            • Roger O.
              • September 7, 2009
              • 209
              JR
              Your absolutely right,sorry I didn't mention the ground,its just as important as the power in.
