Amp meter needle quiver - NCRS Discussion Boards
  • Daniel Y.
    • September 30, 2002
    • 185
    I'm preparing my 66 for PV and I have a quivering needle. intermittently while engine is running. Also when putting turn signal on there's an initial larger quiver, then a normal movement when turn signal is blinking. Any ideas to fix these issues will be greatly appreciated!
    Thank you !
    Dan Young
    65, 67 Duntov x2
    66 bowtie x 2
    71 LT1 TF
    90 ZR1 McCelland
    03 Anniverary
    06 Z06
    Re: Amp meter needle quiver
    I'd expect the ammeter needle to be pretty much rock solid when the car is cruising and electrical load(s) have stablized. But, it's not atypical for the needle to momentarily 'dip' when a fresh new load is introduced. The voltage regulator is electro-mechanical and has a finite response time compared to today's solid-state V-regs...
    • Philip C.
      • December 1, 1984
      • 1117
      Hi Jack, could you put that in english Phil 8063
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11327
        Our 63 seems to act the same way. I'll see it jittery for a while then after everything gets warm and stable it stays pretty steady.
        Rich
        • Joe R.
          • July 31, 1976
          • 4551
          Your Ammeter is going to need replacement before you try for PV. There is a dampening fluid (silicone) in each meter that will keep the pointer from violently dipping in either direction. After time this viscious fluid leaks out and you are left with a meter that will swing widely from "0" when the voltage regulator kicks in or out and will vibrate when you hit a bump in the road.
          Several vendors offer the 63 thru 67 and later models. I just noticed the earlier meters on e-bay. Beware if the meter is coming from the West Coast. Those movements have been known to be very inaccurate.
          Both sources for the meters are getting them made outside the US but the West Coast ones are really bad as the movements are not accurate reproductions of the originals.
          JR
          • Daniel Y.
            • 185
            Thanks Joe - I will check all the connections first but you're probably right - needs replacing. There was allot of past posts on the matter....
            Dan Young
            65, 67 Duntov x2
            66 bowtie x 2
            71 LT1 TF
            90 ZR1 McCelland
            03 Anniverary
            06 Z06
