Rear Spring Banding - NCRS Discussion Boards
Rear Spring Banding
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    Re: Rear Spring Banding
    I also have reused original clips by carefully removing them and reshaping them. I modified a Northern Tool Co crimp tool to get the single side crimps and tested it on flat repro clips. I use a C-Clamp and spring clamps to hold the sides of the strap tightly before crimping. The strap should be allowed to move a bit when the spring leaves move.
    • Mark P.
      • May 13, 2008
      • 934
      Thanks everyone. The modifications Richard did look pretty time consuming. Not just reconfiguring dies. I'll give it a try.
      • Troy P.
        • February 1, 1989
        • 1284
        #18
        Nice photos. I also modified the same tool and have used clamps like you show. We are on the same page.
        Its been a while since I modified the tool but it seems to me that I found two leaves stacked together made a crimp that was somewhat wider than original. So I ground down one leaf to make it thinner.
        I have a set of original bands I cut off and will attempt to pry off the clamps. Perhaps someone will need them.
        I suppose you know that the springs were painted after assembly - after the liners and bands were installed.
        • Keith R.
          • August 31, 2001
          • 660
          #19
          Corvette Central sells the bands with serrated marks.
          Keith MacRae
          NCRS #36692
          New Mexico Chapter
          1960 290HP FI
          2013 427 Convertible
          Shade tree mechanic and
          B-52 pilot extraordinaire
          • Keith R.
            • August 31, 2001
            • 660
            #20
            This is really a two man job. One person holds the bands taut while the other crimps the bands. They do not have to be super taut - in fact, they should fit somewhat loosely around the spring leafs. I rented the crimping tool from CC and found that I could produce a decent crimp after a bit of trial and error and ruining a number of clamps. You have to carefully position the crimping teeths to make sure that the crimp occurs in the middle of the clamp.
            Keith MacRae
            NCRS #36692
            New Mexico Chapter
            1960 290HP FI
