80-82 Differential - NCRS Discussion Boards
80-82 Differential
  • John C.
    • January 1, 2001
    • 171
    80-82 Differential
    What type of posi unit did these use? Is it specific to the 80-82 diff or will a 65-79 work in the housing as well?
    Thank you!
    • 15706
    Re: 80-82 Differential
    ...different carrier and guts architecture - I think Dana 44, where the '63-'79 design was unique to Corvette.
    That's why the equivalent of the '63-'79 3.08:1 axle became 3.07 - different tooth count on the ring and pinion, which effected the second decimal place.
      • 43297
      Duke-----
      Yes, the 80-82 used a Dana-44 rear gear assembly. The posi unit was a Dana unit applicable only to this assembly. It is not interchangeable with any earlier posi nor is an earlier posi interchangeable with the Dana unit.
      1965-79 Corvettes used an Eaton-manufactured posi. The remainder of the unit was manufactured by Chevrolet Gear and Axle.
      • John C.
        • January 1, 2001
        • 171
        Thanks guys!
