Identification Rear Carrier 1964 - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    Identification help please rear carrier housing 1964 CB 10 1862 3871375 LAST NUMBER LOOKS LIKE A 5 3818753-N ( 63-66 ) the OIL PLUG HAS A 32 ON IT. Would I have 3:36 gears ? Thanks
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Identification Rear Carrier 1964
    Well, your carrier has the correct casting 3818753-N for a '63 -early '65. I assume the stamped code is CB_10_18_62. But your rear cover is the (after) early '65 thru "forever" (into the '70s) # 3871735 (upside down when installed), instead of the 3830303 expected for '63 to early '65.
    So I would have someone spin the input versus side yokes to verify ratio. It could be 3.36 posi, or anything else if the yoke and pinion or even the case has been changed.
    • Wayne P.
      • January 23, 2008
      • 444
      Thank you Wayne.
      I will look for a new front cover. The drain hole has been brazed over. I have it out of the car. This does raise questions ?? I guess I will crack the cover and look at the gears. Another Christmas gift.
      • Timothy B.
        • April 30, 1983
        • 5203
        Wayne,
        What's the approx build date on your 64? Is the engine 300hp, 3.36 rear axle is standard with this engine.
        • Wayne P.
          • January 23, 2008
          • 444
          Timothy I believe Dec 8th
          • Wayne P.
            • January 23, 2008
            • 444
            I opened the front cover the gear number is 3735390 11 37 9 62 GM
            • Harry S.
              • July 31, 2002
              • 5349
              Wayne, divide the 37 by 11 and you get 3.36. So you have a carrier that says CB 10 18 62.
              That translates to a 3.36 posi. rear built October 18 th 1962. Plus you verified it still has the 3.36 gear set. The date on the gear is September 1962.
              For a Dec 8th car, looks like a fit!
              Just the rear cover is in question.
              Cheers
              • Wayne P.
                • January 23, 2008
                • 444
                Thanks for all the help.
                Have a great christmas.
                • Bob R.
                  • June 30, 2002
                  • 1596
                  Harry
                  There is one problem wirth the date of the carrier. You have an October 62 carrier in a December built 64. The rear is not dated correctly for the 64.
                  • Harry S.
                    • July 31, 2002
                    • 5349
                    Bob, you are correct, the left side of my brain must be 12 months out of kilter. But it's a great rear for a Dec 8th 63 car. It's too cold here in NH to think about dates properly.
