I have purchased a Paragon repro antenna for my 59 and can't figure out how to intall it. I have looked in the archives all I can find is the obvious. The mast does not retract as far as the original.
When I put the base as far aft and down into the well area of the trunk, the mast is still 2 - 3 inches forward of the hole in the top of the fender. I don't want to bend the mast. Is there a way to separate the mast from the base without destroying the antenna?
They, CC and Paragon, sell a lot of these so someone has to be getting them installed. How?........Help
Sully
Sully
) It gives you a reference point as to where your antenna should go through the body IF the bracket is unmolested & in it's orig. position. The orig. hole where the antenna went thru my 57 has been filled in presumably due to a damaged hole, so I am using an under the dash wire antenna instead. On my 58 the orig. hole is still there & the orig. fender bracket is still there. Everything lines up fine. I suspect that someone has moved your hole in the wrong place, due to previous damage & a weak point. Be sure to check everything carefully before modifying the bracket.
