1957 park brake signal switch - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    are there two styles of park brake signal switches notice bracket is on the other side on switch on right
  • David V.
    • April 30, 1991
    • 88
    Re: 1957 park brake signal switch
    Hey Dan Is it possible to "disassemble" the pass. bracket/switch & "reassemble" it so it will look/resemble the Vette bracket/switch?
    • Dan P.
      • December 1, 1990
      • 683
      no it is offset to the wrong side . This must be a passenger car . It is not A 55-64 maybe A 49-54
      • David V.
        • April 30, 1991
        • 88
        Hey Dan or anybody: I bought a park light jewel off ebay that does not have the bulb "socket." Can you recommend a substitute bulb socket that will work?
        • Dan P.
          • December 1, 1990
          • 683
          1955 1956 passenger car and I think 55-59 trucks are the same
          • Troy P.
            • February 1, 1989
            • 1284
            Huh? Passenger car did not have the brake jewel. Which part on the cars were you thinking of that would provide the correct socket?
            • Dan P.
              • December 1, 1990
              • 683
              it is A accessory . there is one on Ebay right now
              • David V.
                • April 30, 1991
                • 88
                57 Pass. cars did have a parking brake jewel that mounted on a sep. bracket that mounted under the dash. I was hoping to find a late model socket at a local parts store that could be used instead of the original socket that went with the jewel.
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Dan,
                  When I finally got around to installing the e-brake warning light I ran into the same problem with the bracket.
                  With it installed the emergency brake can not be released as the small stop piece hits the bracket.
                  Oh well, no e-brake warning light.
                  Bruce B
